Author Subject: Jetex help
mike rallye
hi all i fitted my new jetex exhaust system last week,and it is spot on . but i recently notice a noise/vibration when i take me foot of the accerater pedal to change gear(intermitenly)and i swear it coming from inside the backbox and was woundering if anyone else has had this problem?.i have checked to make sure it is not catching and the heat shields are all clear to.
any advice would be helpfull
mike
Posted 18th Jan 2011 at 01:37
greenbelt
You might need to bend the hangers slightly or rotate the centre section so it doesn't catch the heatshields Wink
Standard Black 6
Black HBSC6 Smoke
Posted 18th Jan 2011 at 02:55
mike rallye
i have checked the heatshields and the exhaust doesnt catch at all
Posted 18th Jan 2011 at 02:58
greenbelt
How much clearance do you have between the exhaust and the beam?
Standard Black 6
Black HBSC6 Smoke
Posted 18th Jan 2011 at 03:01
mike rallye
erm not sure about that,will have to check. if i was to you different exhaust rubber(i.e something from demon tweeks)would that be better than the standard ones?
Posted 18th Jan 2011 at 03:05
greenbelt
I have uprated rubbers on the backbox and a standard rubber on the centre section.
I bet it is catching slightly on the beam Yes
I had to rotate the centre section and use a mixture of rubbers to get the clearance.
Standard Black 6
Black HBSC6 Smoke
Posted 18th Jan 2011 at 03:25
mike rallye
ok thanks for that. you would happen to know what the size of the uprated rubbers are for the backbox?
Posted 18th Jan 2011 at 03:44
greenbelt
They are powerflex ones I got off ebay ages ago. Don't have a link though but they should still be available.
Standard Black 6
Black HBSC6 Smoke
Posted 18th Jan 2011 at 03:59
russbez
i found using old saggy exhaust mounts helps sometimes in getting exhaust sitting nicely
My Rallye project thread
Posted 18th Jan 2011 at 14:52
james_gti6
i had the same problem, there is a bracket which holds the back bumper on, it is very close to the back box, mine only made the noise when warm, the system was expanding with heat and just touching the bracket.
if i dont see you in the mattress il see you in the spring
Posted 18th Jan 2011 at 15:40
mike rallye
well had another look at this exhaust today and still no joy. will have a look at the bumper bracket tomorrow incase that at fault.
i have spoken to demon tweeks today and i have got me car booked in for saturday for them to have a look.they said it might be a faulty exhaust. if it is faulty and they havent got anymore in stock,what would you guys suggest for another exhausy system which is fairly quite like the jetex is?
Posted 19th Jan 2011 at 01:16
greenbelt
There aren't any! LOL
Jetex or standard.
Standard Black 6
Black HBSC6 Smoke
Posted 19th Jan 2011 at 01:26
mike rallye
ok cheers for that,i will hope it a easy fix or repair then. Thumbs up
Posted 19th Jan 2011 at 02:00
mike rallye
right guys i got a problem with my jetex backbox. i bought this system assuming it is all stainless steel which is what it say on the website . but i now notice there is corrosion on the backbox appearing and the black paint on the box is coming off to.
i have rang tweeks up and i got to take it in on saturday for them to see. would i be right in thinking the backbox is stainless steel to?
Posted 28th Jan 2011 at 02:46
smegal
Jetex seem to do all backboxes in mild/low grade stainless probs for sound. I wouldn't worry.
Try bending the back bracket down. It will only make a noise if it has been fitted out of line but it is an east fix.
Ex SC-6
Now in a Megane R26
Posted 28th Jan 2011 at 03:20
mike rallye
ok thanks for that.
forgot to say ,i managed to sort the vibration out in the end. it turned out to be my down pipe gasket which was broken/crumbled. fitted new down pipe kit all ok now.
Posted 28th Jan 2011 at 03:30
kit
Jetex or standard.
My s/s Powerflow system with two silencers was just as quiet as a Jetex system.
As for the corrosion, iirc Jetex provide a cheaper mild steel version, and a more expensive stainless steel version.
Racing driver, fighter pilot, astronaut, compulsive liar.
Posted 28th Jan 2011 at 04:11
smegal
I'd be interested to hear what they have to say about the backboxes. Mate has just bought a Jetex for his Volvo and the backbox on that is black painted mild (I think it's mild) too.
Ex SC-6
Now in a Megane R26
Posted 28th Jan 2011 at 04:55
matt.gti6
As far as I can tell, Jetex offer a lifetime gurantee against corrosion or breaks on the system we have, so I guess it doesn't matter that much what it is made of!
Posted 28th Jan 2011 at 13:49
smegal
+1.
Ex SC-6
Now in a Megane R26
Posted 28th Jan 2011 at 17:18
spitfire
The Jetex system is made of stainless steel, it is made of T400 Stainless Chromian, the back box is also painted black.
I don't think this is a top notch grade of stainless hence why the back box is painted black, however I actualy prefer this as I think it looks better behind the bumper.
And as has been mentioned they have a lifetime warrenty.
If you aint first, your last!
Posted 28th Jan 2011 at 22:57
Sorry for the slight O/T, but better that than a new thread.
I've been looking for a lighter exhaust than the weird aftermarket one I have at the moment, but don't want anything loud at all, just stainless, light and corrosion-free.
Looks like Jetex is the one to go for Smile
However looking around they do the Jetex sports cats as well. Are these worth it for a n/a car? They're quite a lot extra so I wouldn't want to get one for no reason, or is a de-cat the way to go? Very much not my area of expertise, so any advice is much appreciated Smile
O.
Posted 29th Jan 2011 at 00:17
