displaying posts 1 to 25 of 52
Pages (3): [1] 2 3
Author Subject: How to fully remove inlet Mani?
gti-dan
I followed the FAQ but this only allows the Mani to be pulled about 2'' off the head, what else needs to be removed to get it right off? Is it difficult? Could do with a bit more space for cleaning the faces off prior to fitting new gasket
Posted 10th Jan 2011 at 17:10
anth_gti6
You must have missed a bolt. If I remember right (and I haven't removed one in over 4 years) there is a hidden bolt underneath that you have to get off. Have you removed all the fuel lines etc?
ex white Phase 1 Gti6, killed at cadwell park in November 07
Posted 10th Jan 2011 at 17:15
pugplus!
hi, dont worry this a really easy job. by the sounds of it you have not taken off the loom that goes to all the sensors on the t/b and injectors.
if you take them off and push them down through the inlet it should come off. also make sure the brackets underneath the inlet are off.
hope this helps.
many thanks,richard.
Pugplus Peugeot parts specialists!!
1000`s & 1000`s of new & used parts in stock
International shipment
Genuine Peugeot parts suppliers
A range of Peugeot's for sale
Contact info:
Mob:07532066648 (richard)
Email: pugplus@hotmail.com
Posted 10th Jan 2011 at 17:17
gti-dan
I disconnected 2 plugs off the tb but could see a load of cables still connected underneath, not a plug tho so couldn't unplug. Is there a plug somewhere further down the line?
Will there b any issues in disconnecting injectors and fuel lines etc?
Posted 10th Jan 2011 at 17:39
jbradders
I Think there are 3 on the throttle body area,2 of them are underneath.
Edit: 4 with map sensor
Posted 10th Jan 2011 at 17:45
Yes, the fuel will be under pressure so don't spray yourself in the eye with it. And there is a 13mm? bolt on a bracket underneath, hard to get ar with the small gap between the plenum and the radiator but it wont come off till you remove that first.
Posted 10th Jan 2011 at 17:44
lotek
pull dipstick out aswell Yes
Well, undo the bolt on the dipstic tube if you have'nt already done that yeah! LOL
Posted 10th Jan 2011 at 17:46
gti-dan
Yeah I've undone all those hidden bolts and dipstick etc. the inlet is off, but only a few inches, need to get it right off. It will be the loom underneath. Didnt appear to be a plug though, will have another look nxt week
Posted 10th Jan 2011 at 18:25
gtisid
back of the throttle position sensor there is a clip, have to get it from underneath. think that is what the sensor is. so much easier if you remove the airbox and inlet pipe if you have not already done so
pugless
Phase 1 GTI 6 1996-1997
Subaru Impreza GB270 2007-2008
rare spiderman comics
same day international courier
Posted 10th Jan 2011 at 20:03
jbradders
There is a plug on the icv that is sort of hidden.
Posted 10th Jan 2011 at 20:05
gtisid
it may well be that one
pugless
Posted 10th Jan 2011 at 22:47
cwspellowe
Bingo.
You can't really see it from above, but it's 99% guaranteed it's that one.
Bye bye Sundance Kid Sad
Posted 11th Jan 2011 at 00:39
davewagon
Bump for an old thread!
Why would be the correct torque settings for the manifold bolts?
And what could you use to clean the faces of the inlet and the engine, alcohol? Meths?
Regards, Dave
Team: Moonstone GTI-6™
Team: Working air-con™
ian7675 wrote:
Posted 8th Apr 2012 at 09:46
sharp blade Thumbs up
correct torque settings in the haynes manual.
Posted 8th Apr 2012 at 09:58
Moved to Engines. Smile
Posted 8th Apr 2012 at 10:01
davewagon
Cool, cheers
Edit: won't you risk scraping shut into the cylinders?
Posted 8th Apr 2012 at 10:09
davewagon wrote:
Cool, cheers
When I do things like this, I always get some kitchen towels and screw four of them up into balls and place one in each port. Then you can start scraping. That way when you've finished and all the shards of old gasket are sitting on top of them, you can pull each one out with a set of pliers and the rubbish doesn't fall into the engine. Smile
Posted 8th Apr 2012 at 10:24
davewagon
Thumbs up
Posted 8th Apr 2012 at 10:28
davewagon
Okay, I have just been out and removed the inlet manifold and replaced the paper gasket with a Phillipm PTFE type. Also replaced the resonator with an Aluminium bung to see how that goes.
I was feeling all really wicked with myself and had a high sense of achievement etc etc, however bolts J and K (below) simply will not match back up to the holes.
I'm sure its due to the fact that the new gasket is much thicker than the original one, and has spaced the whole manifold up slightly, but I would like someone to confirm this please?
Do these bolts NEED to go back in, will the manifold have enough support without them?
Why can't I get them back in if they are supposed to??
Regards, Dave
Posted 8th Apr 2012 at 14:28
Fit these bolts first Dave, just a few turns by hand and then get all the other manifold bolts in by a few turns as well, and then you will find they will all fit. Thumbs up
Posted 8th Apr 2012 at 14:37
davewagon
Feck lol!
I've fitted it all back together now (bar those bolts) another few hours to lose yet lol
Cheers Stan
Posted 8th Apr 2012 at 15:13
Best get back out there and fit them then. Yes LOL
Posted 8th Apr 2012 at 15:17
davewagon
Okay, I've just been and done this, didnt take that long in the end lol
HOWEVER!
When i restarted the engine this time the car immediately started over-revving!
We double checked the throttle cable and tried again, this time the car started and started revving again, i pressed the accelerator just to see what that did and the engine dies down.
But the car wont run smoothly now, it makes a horrible cracking/poppoing noise every so often and my dad reckons he saw a spark coming from the injector/manifold bolt when i made a popping noise?
Any suggestions?
Regards, Dave
Posted 8th Apr 2012 at 15:59
atterz
Sounds like an air leak from somewhere, are you 100% you have tightened all the bolts correctly that bolt it to the head. And also is the seal etc ok on the resonator bung?
owain wrote:
Posted 8th Apr 2012 at 16:02
Pages (3): [1] 2 3
