displaying posts 26 to 50 of 52
Pages (3): 1 [2] 3
Author Subject: How to fully remove inlet Mani?
davewagon
I will double check, although i'm postitive i've tightened all bolts tight (maybe even too tight)
The bung should be okay, i gave it another press to make sure it is in tightly (used the O-ring from the Helmzholtz resonator)
If its not this, could there be damage to the fuel rail, is it possible for the injector not to seat properly?
What would cause the popping/cracking?
Thanks for all the help, Dave
Team: Moonstone GTI-6™
Team: Working air-con™
ian7675 wrote:
Posted 8th Apr 2012 at 16:18
atterz
Too tight isnt ideal, do you have a talking wrench Smile ? Yes its highly possible that an injector seal has been damaged if you removed them! I dare say popping/cracking is it back firing due to unmetered air entering and confusing the ECU!
owain wrote:
Posted 8th Apr 2012 at 16:26
Injector seal or that bung isn't sealing correctly in my opinion...
Posted 8th Apr 2012 at 16:44
swiftyboi006
Injector seal Thumbs up
Black p3 Love
Posted 8th Apr 2012 at 16:51
davewagon
I've steeped away from this for an hour or so to visit some family
I'm goin to temporarily say the bung us fine, as it was in and car working properly the first time we fitted the gasket
Therefore the injector not seated properly/seal damage?
How an I check to see which one it is (I.e not sitting properly or buggered)
Should I be able to wiggle it?
I might loosen off the bolts one last time and make sure it is all sitting flush ?
The car seemingly worked fine, all we did was loosen off the bolts to enable the manifold to shift slightly to refit bolts J&K from the guide, then tightened them back up
Would this have been enough to shift an injector?
Regards, Dave
Posted 8th Apr 2012 at 17:15
Best remove the rail and clean it all up and replace anyway just to be sure. Its only 2 bolts after all...
Posted 8th Apr 2012 at 17:18
If it's drivable and you still can't figure it out, feel free to pop over with it. I'm only about 40 mins max from you. Wink
Posted 8th Apr 2012 at 17:22
davewagon
Thank you Stan, that's very generous of you (unfortunately I may take you up on that offer if I can't crack this, for which some beer tokens or an Easter egg are for you lol)
Could you give me a little more info on removing the fuel rail (two bolts you say)?
Does that give me access to injectors without having to remove the manifold again?
Many thanks, Dave
Posted 8th Apr 2012 at 17:54
atterz
Yes it will do mate!
Posted 8th Apr 2012 at 19:26
davewagon
Post #35
Right I had another look but didnt really get very far!
I undid the screws holding the fuel rail to the manifold, and unclipped the plugs into the injectors - but after that didn't really know where to proceed so had a little wiggle and tried to make sure they were all seated properly (although I haven't a clue).
So I tightened everything back up and had another go...
So again it started and revved right up - I then give a little tap to the accelerator and it settled down to running lumpy - then started popping and banging! (you can just see the flash of the explosion where the manifold meets the engine Dunno )
So we turn it off quick sharp, you can just see smoke coming from the manifold on cylinder 2 (second from the left)
I took a video of it, but annoyingly it didn't start banging this time so I couldn't catch that on tape?
Its a bit long, but you can hear the engine over revving from the off - then it dies down and at about 40 secs falls into a repeating cycle where it tries to start revving again, then dies back and starts again? But it didn't bang this time Dunno
So any thoughts, how can I get this fixed tomorrow?
(I'm not sure if it's drivable to Cambridgeshire, and surely everything would be boiling hot by the time I arrived, so I think your bank holiday Monday may be safe after all Stan LOL)
(Edit: oh yeah, and a siren at the end, very apt for Corby Laugh my ass off)
Posted 8th Apr 2012 at 21:11
Post #36
Carl aka Mechanical Repairs is probably closer to you in Leicester than I am to be fair...
Deffo sounds like an air leak. I take it you have plugged the ICV back in properly? Unfortunately, I can't watch the video at the moment as I'm on my phone but will take a look first thing tomorrow. Yes
Posted 8th Apr 2012 at 21:43
davewagon
Post #37
Cheers Stan, appreciate you taking the time to have a look
Erm, I assume it's plugged back in correctly but will have another check tomorrow
Will the banging, and combustion have caused any serious damage, it only did it a handful of times in total?
Posted 8th Apr 2012 at 22:38
ryangti6
Post #38
It shouldn't have done any damage but wont do it much good.
I looks like it hasnt seated against the head properly to me given that you can see that backfire, take all the nuts and bolts back off that hold it to the head and start again ensuring the manifold face is sitting flush with the head.
Did you use a standard gasket along with the ptfe one? I've heard a few people have sealing issues with them so use a standard gasket either side of it.
Ryan
Posted 8th Apr 2012 at 23:26
davewagon
Post #39
Cheers Ryan! That would be handy if that were the issue
Erm no, I scraped all the remnants of the old paper gasket off and just replaced it with the PTFE gasket. Didn't place any type of standard gasket on any side of the PTFE one - was I supposed to, I thought they were a direct replacement.
Posted 9th Apr 2012 at 00:11
Post #40
They are a direct replacement, however I always fit a standard one then the PTFE then a standard one then the manifold just for peace of mind. However, you don't have to do this.
Posted 9th Apr 2012 at 07:40
Post #41
Ok Dave, I've had a look at the video. Yes
It sounds like its hunting for the last half of the video. It's definitely receiving some unmetered air which is sending the ECU in all sorts of directions.
Either the PTFE isn't sealing, or the injectors (unlikely if you didn't actually remove them) or that new bung you fitted is letting some air by. My feeling would be the PTFE, however, best thing to do is to completely remove the manifold, and put some silicone sealant around the edges where the bung sits to seal it properly for sure. Refit the manifold, preferably with standard gaskets either side, or if you don't have them, just make sure you do the bolts up evenly and to the correct torque and then put everything else back together. Thumbs up
Let us know how you get on. Thumbs up
Posted 9th Apr 2012 at 08:40
davewagon
Post #42
Right, thanks very much for the help!
Motor factors seem to be shut for the bank holiday, so extra gaskets are out I fear.
I'm going to have another crack now, will let you know how i get on (although I will need to get my hands on a torque wrench first)
Posted 9th Apr 2012 at 11:08
woody.
Post #43
Have you tried unplugging the battery for 10-15mins to reset the ECU? Probably not the problem but thought I may as well throw it out there!
Posted 9th Apr 2012 at 12:36
davewagon
Post #44
HUZZAH! (Possibly premature, but I think I may have it working again, subject to scrutiny of the below video)
My guess as to what happened was, as I slackened it off to fit and tighten bolts J & K. I tightened these up fully which in turn meant I couldn't then get a proper seal over the manifold gasket.
So I loosened everything off again, put in bolts J & K but only wound them in a few turns, then proceeded to evenly tighten up all bolts around the gasket before returning to tighten bolts J & K.
And it seems to work?
This may be a temporary fix though, here are my questions:
1) All motor factors are shut today, so I could not get my hands on some paper gaskets to sandwich the PTFE one - should I still aim to do this - or leave it well alone now it seems to work?
2) I couldn't get my hands on a torque wrench that goes low enough (If I'm reading correctly, Haynes manual says 20nm for 2.0 ltr manifold bolts [section 4c]).
As such i have done them hand tight, being conscious not to do them bas**rd tight - Should I get my hands on a low range wrench and go round and redo the bolts?
All your help has been massively appreciated Smoke (Certainly got my £5 worth this weekend!)
Strangely, having gone from doing nothing mechanical to my car - I went from taking the manifold from once to three times in the space of two days lol - I also noticed my droplink has completely snapped off, so that's a job for next weekend I feel.
Kind regards,
Dave
Posted 9th Apr 2012 at 15:11
davewagon
Post #45
Cheers Woody, I haven't tried doing this, as the car now seems settled - I may just leave it well alone and go get a curry instead!
Posted 9th Apr 2012 at 15:12
Post #46
Sounds good to me Dave! Yes
This scenario is exactly what happened, you needed to make sure that you got the gasket face seating nice and correct and then tighten J and K bolts down afterwards. Thumbs up
Seeing as its now running fine, I wouldn't mess with it again putting extra gaskets in. No
Well done Dave! Cheers
Posted 9th Apr 2012 at 17:27
davewagon
Post #47
Cheers matey, it's sorted now so there are other issues to tend to
Cheers for your help!
Dave
Posted 9th Apr 2012 at 17:57
Post #48
No worries mate, glad you got it resolved. Cheers
Posted 9th Apr 2012 at 18:41
atterz
Post #49
Glad its sorted out mate Big grin Let me know how you go on with the bung/gasket. Been interested in doing this to mine!
Posted 9th Apr 2012 at 19:04
Post #50
I've got a feeling it will lose torque through doing this, but as I have never tried it myself I will await and see the results. Smile
Posted 9th Apr 2012 at 19:22
Pages (3): 1 [2] 3
