Author Subject: No inlet resonator
I removed mine when I converted my 309 Gti,and a couple of forum users reckon you lose torqueBlink
But I searched the net and the info I found said the only thing resonators do is reduce noiseWink
Pretty sure they are called Helmholtz ResonatorsSmile
Posted 25th Dec 2010 at 04:19
midlife
Just make sure the hole is bunged up properly!
Cool
Team 330™Cool
Team "no front end or engine"
Posted 25th Dec 2010 at 03:43
not quite. it is to do with air cavities and peugeot designed it so a consistent airflow balance is taken in. its not just about the noise but yes it is for that too. you have your nice smooth torque curve to thank for it
sure, it'll work fine without it, but it isn't there for comical value. if it wasn't needed.....
theres one coming off the airbox aswell
Posted 25th Dec 2010 at 04:59
jimbamboon
Yes helmholtz , ive turned into a bit of a perfectionist and want to make sure that my engine is functioning as close to standard as possible with minimal losses, would you recommend I put one back on? As when I first got the car I did feel like it lacked a bit of torque down low
clicky code for my benefit
Posted 25th Dec 2010 at 12:56
joevts
are you talking about the big one under the fannymold or the little clog shaped thing on the airbox?
Posted 25th Dec 2010 at 14:45
the torque thing I have heard mention of before, try it!
if only there was a 6 owner with a RR to hand, we could see what difference this and advancing cams and fitting induction kits made LOL
(apart from noise...)
Posted 25th Dec 2010 at 15:35
jimbamboon
yeh talking about the helmholtz under the fannimold
Posted 25th Dec 2010 at 18:48
Have you got the info on Pug designing it to hand by any chance??????Smile
If not I'll stick with the info I found that says its all noise relatedBig grin
Posted 26th Dec 2010 at 01:22
Remove it and see the noise difference then..
Tell a lie - they aren't used just on peugeots. They are used on jet engines and lots of other applications too. They aren't just for noise. I swapped an inlet to one with a bung in once before buying the resonator and noise wasn't any different tbh
Posted 26th Dec 2010 at 01:49
(On my phone so don't even know if that posted)
Posted 26th Dec 2010 at 01:50
Usually both to cancel out unpleasant resonance notes and to to help fill in dips in the torque curve that the camshaft + inlet manifold length gives, albeit usually at the slight expense of peak torque.
Posted 26th Dec 2010 at 02:37
So to summarise: yes it does you a load of good and removing it is barely a boredom exercise?
Posted 26th Dec 2010 at 02:52
Depends, sometimes if you've altered the head/manifold or cams they'll hurt performance as they're no longer matched with each other - in that case I'd bin it, standard car with bolt on bits? Probably not.
Be interesting to see a back to back on the dyno.
Posted 26th Dec 2010 at 02:59
mattgti6phase2
Have removed mine and binges it then made the airbox completely air tight and found that you get a slight induction noise from the snorkel. I also found better throttle response.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 27th Dec 2010 at 19:47
jimmyhackers
im trying to get to the route of this on my thread Razz
looks like back to back no ones done it.
could be an interesting one if i turn up to pugfest. (we get a rolling road dont we?)
seeing as to convert between the 4 possible comibinations will take all of 5 minutes Razz
Posted 8th Jul 2011 at 07:21
No rolling road there last year?Unsure
I've removed mine on the Rallye,and also the one fitted to airbox and blanked off the hole into airbox,modded snorkel to make a 'ram-air' effect into airbox,fitted a RamAir induction kit inside the standard airbox Wink
At a recent rolling road day mine did 180bhp(highest of the day on standard inlet/injectionBig grin )and also highest torque figureWink
Other mods are Magnex de-cat and systemSmile
So I still stick with the info I found the resonator is for noise reductionRazz
Posted 10th Jul 2011 at 04:26
jimmyhackers
tbh that was my first inclination. anything that isnt for power genrally works against it.
i was thinking of a decat staright through pipeand i might just remove this mr hermholtz phooey from my car.
have you done anything else to your engine? i wouldnt mind some info on cheeky mods that ive missed Smile
i hopeing for somewhere around that 180 figure. hopefully i get neare it after next payday
gonna get a new rear suspension setup and do a full service Smile
thanks for any info in advance
Posted 11th Jul 2011 at 01:45
bobdylan_55
to put it simply hemoltz resonators balance out air distribution to each cylinder. The calculations can get very complicated, but it does do something and can be quite important on tuned engines running plenum chambers.
309 GTi6-T
Posted 11th Jul 2011 at 02:14
