displaying posts 1 to 25 of 31
Author Subject: strength of a xu104jrs 8:3:1
zxturbo400
Would a xu10 be safe at 300-350bhp with a dp engineering decomp kit and standard internals?
Of course will have management and fueling sorted
cheers
Posted 21st Dec 2010 at 06:27
mabgti
NV motors
simple termsNo..
the rods wont handle the stress of boost! max at280bhp with decomp plate!
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 21st Dec 2010 at 06:46
zxturbo400
cheers, ive seen theres a 328bhp zx dp engineering built which is a standard xu10? and some bloke on here from brazil made 443 atws on a standard bottom end too?
Ive sent a email to dp now to see what they will come back with
Smile cheers,cal
Posted 21st Dec 2010 at 07:51
smegal
If you can afford an new engine if it goes tits up go for it.
It will be interesting to see. I want it to work personally.
Ex SC-6
Now in a Megane R26
Posted 21st Dec 2010 at 08:24
How would it have standard internals on the bottom end if the compression ration was 8.3:1 as the thread title suggests??
Standard compression ratio on these is 10.8:1 Yes
Stan.
Posted 21st Dec 2010 at 12:29
If it's any help, I run forged internals in an XU10J4RS which is running a compression ratio of 8:1 and currently producing 454bhp, so it can be done. Smile
Stan.
Posted 21st Dec 2010 at 12:34
Theres a guy over on 205 gti drivers with an *standard* S16 bottom end,decomp plate and a GT30 turbo running 446bhp! Crazy
Posted 21st Dec 2010 at 13:29
How long has that been going?
Posted 21st Dec 2010 at 14:30
Over 5k Crazy
Posted 21st Dec 2010 at 16:05
zxturbo400
is that the blue 205 pal? that was built in 2008,using dp parts.
only thing that im not too sure on management , ive been looking at omex 600,
Id run a dp decomp kit to 8:3:1,welders nightmare manifold and gt28rs at 20 psi, external wastegate, ive got 2 zx volcane td boxes here which i could try but i may aswell use the 6 gearbox and flywheel and linkages from the gti6 ( which il buy the whole car, use the parts i need like fuel tank etc then sell the rest on here)
with out pistons and rods, bearings etc il b e saving at least £2k
300-350bhp 5 door zx volcane would be an alright sleeper
Posted 21st Dec 2010 at 18:08
Yes its the blue one mate Smile
Posted 21st Dec 2010 at 18:27
smegal
Stan.
Decompression plate.
Ex SC-6
Now in a Megane R26
Posted 21st Dec 2010 at 20:50
zxturbo400
Right guys spoke to peiter at dp earlier and he gave me a list of what id need from them, turbo kit excluding the gt2871rs as i can get one cheaper elsewhere, i also spoke to a helpful lad at pug1off about the loom and emerald ecu id need, injectors and fpr from a 2002+ quickslver.
Cost ive added up including the gti6 for parts is £4800. Thats for 300-350 bhp with a comp ratio of 8:3:1 or 8:8:1, i was also told not to use the 6 speed box as its weak, so im going to sell that on and try something else, i have a couple of 306 and zx diesel boxes i might try but ratios might be shite.
List of what il need so far is
(gti6 donor car forSmile
Engine
driveshafts ( i have spares though)
flywheel
inlet mani and loom
front brakes
fuel tank as the zx will be diesel
fuel lines
and many other little bits but the rest will be sold on
Other parts:
Dp welders nightmare kit
38mm external wastegate with screamer
GT2871RS
Dp decomp kit to 8:3:1
ported head with 0.10 skim
paddle clutch
siemens injectors 600cc indeally
walbro 255 pump
3.5 bar fpr
2.5-3 bar map sensor
emerald ecu with custom loom, launch control and 7600rpm limit
large fmic with 2.5" boost pipes
3" turbo back exhaust with no boxes
new cambelt and water pump
magnecour kv8.5 leads
iridium plugs
and many other wee bits and bobs
Tonmorow im going to ring up a few more people for advice on what boost to run and what turbo/gearbox to have which would suit.
Id keep the xu10 in the gti6 but at 19 my insurance is only £1100 fc on a volcane, plus ive had a few zx's and 306 dturbos before and prefer the ugly quirckyness of the zx
cheers!
Posted 22nd Dec 2010 at 00:41
brownboy
will the zx not be the same insurance as the gti6 as it will have the engine and a big f*ck off turbo or will you not declare that
Posted 22nd Dec 2010 at 00:59
zxturbo400
No comment Love
Posted 22nd Dec 2010 at 01:04
brownboy
zxturbo400 wrote:
No comment Love
So what do you do when you stack it into someone in your rusty old zx shitbox seriously hurting them and your insurance is invalid
Posted 22nd Dec 2010 at 01:06
zxturbo400
so? run away and cry?nah, obviosuly dont drive a rust old shitbox? and why do i have to bin it? why cant they crash into me?
Theres also thousands of people that think zx volcanes are cool comfy handling cars, were the best small family car ( same as the 306) till the focus came out
Posted 22nd Dec 2010 at 01:13
brownboy
I hope someone does crash in to you and writes it off and then takes you to court for being on the road with invalid insurance its c*nts like you who are pushing up the prices if you cant afford to declare the mods then simple dont mod it
Posted 22nd Dec 2010 at 01:19
zxturbo400
thanks pal
Posted 22nd Dec 2010 at 01:29
binkagti
GTI6 box will take 300 bhp and 300 ft/lbs, well mine is and is still fine, but get some insurance mate.
TEAM Supercharged Rallye
Posted 22nd Dec 2010 at 03:15
mabgti
NV motors
or a shot peened one will handle a bit more...
brazilians are using methanolYes
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 22nd Dec 2010 at 03:29
zxturbo400
yea of course il be insured, £1100 fc on my own 2 years ncb, can you imagine if i said yea it has a 2.0 16v turbo engine producing 300 odd bhp? would go from group 10 to 20 pmsl,however... there still is a way i can insure it with mods! Hmmm ideas!
zxturbo400
methanol? isnt that was americans use for big block v8s with over 800+?
whats the difference from say ron 99
Posted 22nd Dec 2010 at 03:30
cwspellowe
Roll eyes
That is all.
Bye bye Sundance Kid Sad
Posted 22nd Dec 2010 at 04:31
miles
Bit luck of the draw really, you maybe lucky you may not as with any engine unless you start x-raying components you never know how good they are, I;ve blown up std 1.9 205's (Very similar XU Engine) and others with 250bhp are fine.
Having used a few ECU's now I'm converting back to Omex for simple mapping and better mapping points, Emerald's + is you can get it to run the 4 coil packs at the std cost compared to the Omex you need the 710 which yes costs a little more but you'll get this back on mapping costs unless you goto Emerald Direct.
Nice sleeper anyway, Be even better in a AX or deadly.
www.pugracing.com
Posted 22nd Dec 2010 at 05:01
