Author Subject: poss fuel pump problem
jay82rs
hi all my mrs went to go out in the car before and started it whilst she was gunna de-ice it. it ran for around 2 mins approx and just stopped. when i went out to see what is up the fuel pump doesnt seem to be kicking in at all. checked fuse in engine bay and thats fine. tried disconnecting battery for a few mins and still nothing wont even prime. am i right to believe the pump has gave up??? if so where can i find one? a bit cheap if poss with it been so close to xmas. any info is really greatfull. many thanks jay
Posted 21st Dec 2010 at 01:36
Check all the fuses in the passenger compartment below the steering column....
Stan.
Posted 21st Dec 2010 at 03:47
chris with a pug
have u checked the relay on the battery box. could of died
Posted 21st Dec 2010 at 05:12
Roll eyes
That is also another good suggestion....Test the pump by putting 12v directly to the top of it, and see if it runs. If it does, you know the pump itself is ok. Thumbs up
Stan.
Posted 21st Dec 2010 at 12:33
jay82rs
hi thanks for replys. where bouts on battery box is this relay? thanks again jay
Posted 21st Dec 2010 at 22:39
Its the relay attached to the rear of the battery box by a 8mm nut
Posted 21st Dec 2010 at 22:49
jay82rs
ok thanks very much its snowing now so will get a look tommorrow. thanks again
Posted 21st Dec 2010 at 22:57
jay82rs
hi, i bought a new relay that bolts to the back of the battery box and still no joy so ive removed the pump wired it to the battery and it works. ive tested voltage to the multi plug at the pump and im getting 6volts which obviously aint enough to make it run. wat else could it be?? ive pressed the fuel cut off switch next to battery and still no joy. is there a way i can by pass the fuel cut off switch to determin if this is at fault? thanks jay
Posted 23rd Dec 2010 at 20:49
You could take the plug off the fuel cut off switch and bridge it, this would test whether the switch is faulty.
Have you checked the fuses as I suggested??
Stan.
Posted 24th Dec 2010 at 04:39
jay82rs
hi stan. yeh ive checked the fuses all where ok. ill do thatwith fuel cut off switch thanks.. and if still no go will check my earths and then wiring. just find it really strange that it was running whilst de-icing it then it died... i was possibly thinking water/snow in one of the connectors on the bottom side of the inner wing on passanger side and its frozen. will get a look at some point when finished christmas rush..
merry christmas to you all
Jay
Posted 24th Dec 2010 at 13:48
Roll eyes
That is of course possible, check these connections and also the engine bay earths....let us know your findings, have a good Christmas mate. Smile
Stan.
Posted 25th Dec 2010 at 00:06
jay82rs
well checked the earths and cleaned up connections and still no joy.
im getting 10.4volts at the connector to the pump when you 1st put ignition on. this stage will be it priming..
when i turn the car over im getting max out put 7volts to the connector and after say 3 seconds it has dropped down to 5volts..
this ia totally got me stumpped now and its not very often im stuck for ideas or things to check..
is there any where on this site or on the net i can get a wiring diagram for this 306 gti-6 so i can trace wiring from fuel pump back to the feed..
thanks jay
Posted 27th Dec 2010 at 18:40
