Author Subject: 406 brembo rotors?
v6saloon
hi guys, just wandered if anyone knew of anywhere that supplies rotors that would be a direct fit for a 406 with brembo's as i am after something lighter than the standard 305mm disc, cheers.
205 mi16
405 Mi16x4 restoration project
406 v6 saloon track car project/daily driver
508 Hdi
Posted 17th Dec 2010 at 04:02
yeah, any shop that sells xantia/C5 288x28mm discs.
seeing as that's what you need when they go on a 306, and they do weigh a little bit less than the 305's.
unless you mean separate alloy bells and rotors? in which case the only kit I know of is Ash's Pendulum motorsport kits that need 17" wheels minimum.
Posted 17th Dec 2010 at 04:09
v6saloon
hi, they will be on my 406 not a 306 so i can stick with the larger disc, yes i meant seperate bells and rotors Smile been scouring the net but as soon as you type in 406 nobody seems to do anything Angry
205 mi16
508 Hdi
Posted 17th Dec 2010 at 04:21
not surprised LOL
you'll almost certainly be looking at a custom arrangement for what you intend, might be a little tricky to make up as they have such a low offset (effectively zero, i.e the front face of the bell is flush with the rotor)
Posted 17th Dec 2010 at 04:25
v6saloon
may just stick with the standard 305mm ones then (i suppose drilled an d grooved could shed a fiew grams )Whistle
plus i was looking for some pro race 1.2's and to get them to fit over the brembo;s i need 17" 7.5j! was hoping to use 16" 7jCrazy
205 mi16
508 Hdi
Posted 17th Dec 2010 at 04:29
Really? The standard starfish are only 16" though?! They aren't light but really suit any 406 imo
Posted 17th Dec 2010 at 04:47
v6saloon
i know, i was surprised too but have been told by several wheel suppliers that it is correct, i do love the looks of my starfish wheels but want to go as lightweight as i can (but limited by the wallet hence pro race rather than alleggera's which i wanted )Love
so now i need to decide wether to go down the brembo route and get 17" 7.5j td's or stick with the standard brakes and get some good discs and pads and go for some 16" 7j td's decisions decisions Smile
205 mi16
508 Hdi
Posted 17th Dec 2010 at 04:54
would think a 16" could fit ok, the caliper sits further away from the hub on the 406 (hence the larger disc) so should fit, though the lower disc offset may cause issues.
I think this was an issue many coupe owners found when looking for aftermarket wheels, the 16" "starfish" wheels are ET12 BBS wheels.
Posted 17th Dec 2010 at 04:56
v6saloon
didn't realise they were that low (et12) the 16" td's are et16 so that is only 4mm difference
205 mi16
508 Hdi
Posted 17th Dec 2010 at 05:09
v6saloon
do any of you guys know if a 225 45 16 tyre would fit ok on a 7j rim? they are yoko a048's
205 mi16
508 Hdi
Posted 17th Dec 2010 at 05:16
yup, even the 15 x 6.5's are ET12, all the other wheels for the Coupe are ET12, even the 16x7" steelies.
225 might be a tad wide for a 7" rim Unsure
Posted 17th Dec 2010 at 05:17
v6saloon
i thought it would be a little wide but they are for sale at rhe right price so am very tempted
205 mi16
508 Hdi
Posted 17th Dec 2010 at 05:19
v6saloon
the 16x7" steelies.
don't suppose you know the weight of these do you?
205 mi16
508 Hdi
Posted 17th Dec 2010 at 05:37
I'm sure my 16" starfish alloys on the estate run 215 or 225s. Will check in the morning when its back.
The 1.2s will be a lot lighter than anything standard in that size, if you can get them to fit.
Posted 17th Dec 2010 at 14:07
mr swampy s16
**BAD SELLER**
the 16" starfish on my coupe are running 225 toyo tyres all around
Posted 17th Dec 2010 at 15:26
velar
I run an ex btcc 406 coupe, with standard front wishbones and hubs.
I looked long and hard for alloy bells for the car, and found a couple of options.
Use the alloy bells from Ash's a kit that is designed for the 306 and 310mm discs.Problem here is that the disc offset is different, so you would need spacers inside the bells.
Use ford cosworth bells, again the offset is wrong.
I ended up using Focus RS discs (225mm) but these are quite heavy.
Running 225 45 17 tyres on 7' rims, (225 is the max for 7' though, tried 235 45 and the tyre was deforming a bit to much)
Posted 17th Dec 2010 at 18:41
v6saloon
well i think i will just try some good discs and pads on the standard brakes then as i don't really want to use spaces as i want to keep the unsprung mass to a minimum, just out of curiosity what size spacers would you need with ash's rotors and bells? my front wheels are already about as far out as allowed, ant more and they would be sticking out the arches
205 mi16
508 Hdi
Posted 19th Dec 2010 at 14:00
velar
Not sure as I have never seen Ash's kit in the flesh, but I think here is about 5mm difference in disc offset betwean the 306 and 406.
If you use a wheel with 5mm to 10mm less offset( ET 20-25 ish), then the spacer weight is usually cancelled out by the wheel being a bit lighter.( 5mm spacers are very light anyway)
Posted 19th Dec 2010 at 22:01
