Author Subject: Crank position
When I bought my Rallye the head was allready off it,belt snappedNinja
So not 100% sure if the bottom pulleys ok,cause engine could have turned over abit without the head on cause car has been trailored twice since head removedRoll eyes
Pretty sure I read up on here about someway of timing up the crank by looking at where the woodruff key points too?Smile
But can't find it now I need itWhistle
Posted 11th Dec 2010 at 02:19
cosmic spanner
Moral objector
Tried doing a search for "woodruff"? There's only a handful of threads and the bottom one "Crank Pulley & Locking" looks useful.. Wink
Democracy is two wolves and a lamb voting on what to have for lunch..
..Liberty is a well-armed lamb contesting the vote.
Project é - my 306 project thread.
Posted 11th Dec 2010 at 02:29
CheersLOL
Can't believe I wrote woodruff in my post but did not search it!Whistle
Posted 12th Dec 2010 at 02:08
jord294
or use an 8v xu bottom pully just to line it up Wink
Posted 12th Dec 2010 at 02:20
Looks like its slippedAngry
Woodruff key is pointing to the bolt at 3 o'clock when pulley is lined up with locking holeBlink
Posted 13th Dec 2010 at 15:28
how many degrees off does that look like? IIRC its 70 degrees from the key to the pin hole.
Posted 13th Dec 2010 at 15:30
180 degrees ain't it?Unsure
If I put the woodruff key pointing to the bolt at 9 o'clock the timing pin hole is down around 25 past the hour sort of areaAngry
Posted 13th Dec 2010 at 15:43
that be donald ducked LOL
Posted 13th Dec 2010 at 15:47
