displaying posts 1 to 25 of 33
Author Subject: Rubber Roof strips
My drivers side one was lifting up by the the door, so i went out today and took it off after reading they push into position and are not glued,
Anyway when i took it off it turned out it was glued at the end (literally the edge where the boot opens) by where it is glued is a small (about 1 cm) area of bare metal.
Basically the plan was to paint up the bare metal as well as i can with primer>paint>laquer
(theres still some silicon i cant get off, and taking it off in some areas made the bare metal area get bigger)
anyway i cant put the seal back on as its a bit bent so i was wondering if you can get them from peugeot? And do they really just push in? it seems like theres nothing to hold onto
Posted 9th Dec 2010 at 21:52
jord294
not available from dealers anymore Angry
i needed some, and luckily i got a pair off one of the forum members Big grin
Posted 9th Dec 2010 at 22:00
oh man seriously? that sucks. Might have to just seal it down then as it is. Is that a good idea though as surely if it was they would be glued in anyway? would it like prevent water running to the boot etc?
Posted 9th Dec 2010 at 22:48
CUJ
I've got a pair of these for sale if you're after a replacement.
340 horses
Posted 9th Dec 2010 at 22:51
they in Good condition though? mine look like amazing but are actually bent as hell.
If they are straight i would be interested in them though
Posted 9th Dec 2010 at 22:59
jord294
for reference:-
there are 2 different types
Posted 9th Dec 2010 at 23:00
really? is it a simple Ph1/p2-p3 type situation or are we talking luck of the draw.
my car is a T reg phase 3
Posted 9th Dec 2010 at 23:02
jord294
not sure
as i got some from a '98 car to go on a '98 car and they were to narrow.
the ones on my '98 car are the same as my '00 car Crazy
pot luck i reckon
Posted 9th Dec 2010 at 23:23
odd that.. bloody french
Posted 9th Dec 2010 at 23:36
CUJ
I'll take a look tomorrow and let you know, I'm sure they are straight but will clean them up and give you a shout. My car was a T reg also so should be same.
340 horses
Posted 9th Dec 2010 at 23:49
Cheers for that dude Smile
Posted 9th Dec 2010 at 23:51
honestly3k
Do you mean the rubber strip that goes in here?
I got one new from peugeot about 3 months ago for £9.40 inc VAT.
Posted 10th Dec 2010 at 00:38
jord294
that's the one, but i'd imagine you got the narrower type which isn't handed
Posted 10th Dec 2010 at 00:43
honestly3k
What do you mean?
The one i got from pug was wider than the original on the other side...only slightly tho.
It fits better.
Posted 10th Dec 2010 at 00:51
Hmm intriguing.....
3 months ago eh
Posted 10th Dec 2010 at 01:28
honestly3k
02/08/10 to be precise...
Part number: P00008319E9 £8.18 plus VAT (£9.61)
Posted 10th Dec 2010 at 02:01
jord294
that part number is for the ones that can be used either side of the roof - non handed
both cars of different years i have, have the NLA handed mouldings
Posted 10th Dec 2010 at 02:19
honestly3k
Why would you need handed? Smile
Posted 10th Dec 2010 at 02:21
smegal
The handed ones are like £40 a side.
Ex SC-6
Now in a Megane R26
Posted 10th Dec 2010 at 02:23
honestly3k
And why is that? Razz
Posted 10th Dec 2010 at 02:24
jord294
it could be to do with the little rubber pieces that tucks under door seals Crazy
Posted 10th Dec 2010 at 02:27
how can you tell if there handed or not?
Posted 10th Dec 2010 at 03:28
^^^We have a winner. A not needed part which is why they unengineered it on later models.
Posted 10th Dec 2010 at 03:29
Remove part and see if it has a flap protruding. Obviously the flap relates to fitting under the door seal which are on opposite sides of the car meaning the part has to be protruding the appropriate direction to fit under the door seal.
This is handed.
Posted 10th Dec 2010 at 03:32
so some of them have no rubber that goes under the door?
couldnt you tell by just opening the door?
Posted 10th Dec 2010 at 03:33
