Author Subject: fitting solid rear mounts
gti-dan
I might have a go myself but am concerned i will not get the beam lined up straight!
Is this something easy to check? would a garage be able to do it much more easily?
Posted 9th Dec 2010 at 02:00
When I did mine there really wasn't much in the way of play, I certainly didn't do any kind of lining up.
If you're worried I'd get the front tracking done before, then they could probably set up the rears to be in line with those.
In all honesty I wouldn't worry though Smile
Posted 9th Dec 2010 at 02:07
miles
Simple off and on, nothing really to line up other than the rear mounts, the front ones don't move at all
www.pugracing.com
Posted 9th Dec 2010 at 07:05
nxa
Does anyone know the Torque settings for the bolts in the boot?
cheers
Posted 10th Dec 2010 at 10:59
Tight.
Literally, just be sensible about it. I did mine up with a decent socket set and just did them as tight as I could. It's not a cylinder head, nothing's going to warp, just tight will do nicely Smile
Posted 10th Dec 2010 at 12:54
i overtightened mine and they sheared the stud off. rewelded them in a hardcore fashion and they are fine
p*ss easy job though. i had my beam on and off about 8 times when i sheared them, i was losing the plot!
Posted 10th Dec 2010 at 14:04
Ah yes, I forgot to warn you - if you're a beefcake like Rikky then finger tight will do LOL
Posted 10th Dec 2010 at 14:25
jord294
cheers
only about 40Nm Wink
Posted 10th Dec 2010 at 15:37
nxa
jord294 wrote:
cheers
Thanks mate
Posted 10th Dec 2010 at 15:54
