displaying posts 1 to 25 of 33
Author Subject: [URGENT] - still won't start
cwspellowe
Right, so i've cleaned up the dodgy earths in and around the engine bay and charged the battery, all was well I hoped.
Now when it does start, it splutters and dies rather than revs. Had a poke around under the bonnet and it would appear the injector on number 1 cyclinder is leaking badly, stinks of petrol and it's stripped the nice shiny paint off the manifold.
If the leak's really bad, could this cause the fuel pressure to drop so much that the car won't run? When I had it fired up it spluttered like it was on just a couple of cylinders...
Thanks in advance
Bye bye Sundance Kid Sad
Posted 12th Dec 2010 at 21:38
Yes it would kill the fuel pressure. Might be worth changing the injectors and fuel pressure regulator over to some other and see if it cures it.
Could be the regulator has gone up the spout and the injector can't handle the extra pressure.
Posted 8th Dec 2010 at 18:56
cwspellowe
true. I remember when i painted the rail one of the seals looked suspect, threw on some sealant to lend a hand but that might have given up the ghost with the -15 at night here...
Posted 8th Dec 2010 at 20:15
cwspellowe
Crap, i still can't figure this out.
Replaced all the injector seals and fuel filter, took the fuel feed pipe off and cranked the engine and it provides a nice steady flow of fuel. The seals mean the rail now holds pressure and i'd hoped that would solve the issues i'm having. But it didn't.
So as it stands.. I have spark. I have fuel. The belt is lined up correctly and not slipped, so I have compression. The engine turns over on the starter and occasionally it fires, but more like a cough than starting up. But the fact it splutters means it's not an immobiliser issue, if that was f*cked it would stop the engine from even trying to start up. It should start...
...so why doesn't it? Hmm
Cam sensor possibly??
Posted 12th Dec 2010 at 22:33
Rich E Forum Admin
Blocked exhaust?
Posted 12th Dec 2010 at 22:09
Blocked exhaust is a good call Rich, cwspellowe do you have a CAT fitted??
Posted 12th Dec 2010 at 22:34
His car is decat Yes
Posted 12th Dec 2010 at 22:51
cwspellowe
Correct, decatted.
I just don't understand why it would be blocked now? It was running, changed the starter over, it fired up ok, turned it off and now it won't start again Huh?
Posted 12th Dec 2010 at 23:24
chrisd306
Did you not change a cam sensor or crank sensor recently? it still ok mate?
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 13th Dec 2010 at 00:58
rallyeash
crank sensor is where my bet is.
309 3dr K20 Type R
Posted 13th Dec 2010 at 01:02
cwspellowe
Didn't change the crank sensor as Mei said I wouldn't get a spark if it was faulty. Although i'm wondering if it's causing an intermittent spark, making it splutter then die off again...
Posted 13th Dec 2010 at 01:05
rallyeash
hmm, ive just had a scan through the other thread, blocked fuel filter when the tank was very low and pulled some crap through?
although on an old mi16 engine where the crank sensor was dodgy although it would still start, (so had a spark could of been weak though) it wouldnt rev up and run very bad.
309 3dr K20 Type R
Posted 13th Dec 2010 at 01:08
cwspellowe
Fuel filter's been replaced, and i've had the feed pipe off to check for flow so i know fuelling's ok.
I'll try crank sensor and see what happens
Posted 13th Dec 2010 at 01:09
chrisd306
i know my old mans 911 when the crank sensor on it was fegucked!! you sometimes got it to fire up, you tried bump starting it?
& Audi Q5 S Line
Posted 13th Dec 2010 at 01:10
cwspellowe
Yep, still won't fire, can feel the engine turning over but that's about it
Posted 13th Dec 2010 at 01:11
rallyeash
try a crank sensor then bud,think there only £20 or so from a stealers
309 3dr K20 Type R
Posted 13th Dec 2010 at 01:14
cwspellowe
Mine won't get any parts in for another 2 weeks due to their backlog Sad
2nd hand ftw as a temp measure. Chrisd you got eddygti6's number?
Posted 13th Dec 2010 at 01:15
chrisd306
sending you his number in pm mate, if he hasnt got 1 i may have 1 but no home til wednesday lunchtime
& Audi Q5 S Line
Posted 13th Dec 2010 at 01:31
cwspellowe
Cheers mate, he offered me one in my wanted thread so hopefully he has one still.
If someone could show me a picture of where the sensor is too that'd be lovely, had a poke around but can't see anything obvious
Posted 13th Dec 2010 at 01:32
rallyeash
top of the box buddy, close to the engine.
well it is on 5 speed box's so i persume the 6 speed is the same...
309 3dr K20 Type R
Posted 13th Dec 2010 at 01:36
phat 206
Hi mate, if you want I could pop over 2morrow nite with PPS and my 6 to have a look.
Rab E.
Puggy Spanner Monkey. 607 HDi SE 205 1.6 CTI 306 GTI-6 205 1.6 GTI Grass Track Car 405 MI16x4
Posted 13th Dec 2010 at 01:48
tea boy
You see that brown plug, follow the wire back and it will take you to the crank sensor.
Two m6 bolts (10mm head).
It is a bit of a cnut to get to but not impossible.
There is a bit about testing the sensor in the FAQ somewhere. Easy test if you have an AVO meter.
Make tea, not war.
If it ain't broke......fix it until it is.
Posted 13th Dec 2010 at 02:10
cwspellowe
Balls, it'll be in a similar area to the earth then, and that was a ballache to get to.
It's going on diags tomorrow so we'll see if there's any error codes flying about, might give a clue.
Posted 13th Dec 2010 at 02:11
cooper666
has it got coolant in it could be a cracked block
have you compresion tested it.
clio r27
ps3 id:cooperkloe
Posted 13th Dec 2010 at 02:15
