Hi guys, I have just got my hands on a 1998 gti6 Ph2. But it has an electrical problem, there doesnt seem to be a spark and it wont run. I have checked a few threads on here and I have done the following: Fuel pump, is priming and pumping fuel through.
Earth, is working fine checked this from the spark rocker gasket to the battery with a multimeter and is earthing fine.
I have had a plug out to look for a spark touching it to earth and got nothing.
Took apart the key checked the transponder still in place and looks ok, I dont know how to check this other than that?
I took out the multi functional relay (behind the ECU) cleaned this and checked all connection and refitted (is there any other way I can check this) .
Is there anything else I can do before I look into a diagnostic guy out?
Also one more thing does anyone have any kind of diagnostic kit thats would be worth getting hold of. I have had a look at a few other threads and it seems you can get a OBD cable and download some software?
The car is in Nantwich is anyone is local with diagnostic kit (worth a shot,
)?Thanks in advance, Andy
ando
