displaying posts 51 to 75 of 143
Pages (6): first .. 2 [3] 4 .. last
Author Subject: *AEM Wideband AFR Gauge kits*
ballardpaul
Post #51
Received mine yesterday thanks Mabz. Nice bit of kit, little bit unsure how to wire it to the ecu so would also be interested in a guide?
Nissan 350Z (300 BHP)
Posted 6th Jan 2011 at 17:05
Post #52
I read the instructions, seemed pretty simple to me, there's only 3 wires to connect up in most applications, the 4th is unused by many.
http://www.aemelectronics.com/Images/Products/Installation%20Instructions%2030-4100.pdf
Posted 6th Jan 2011 at 17:43
mcfc1987
Post #53
Does the kit come with the bung to weld on to the exhaust?
Posted 6th Jan 2011 at 18:08
smegal
Post #54
yes.
Ex SC-6
Now in a Megane R26
Posted 6th Jan 2011 at 18:10
cosmic spanner
Moral objector
Post #55
Has this group buy finished?
Democracy is two wolves and a lamb voting on what to have for lunch..
..Liberty is a well-armed lamb contesting the vote.
Project é - my 306 project thread.
Posted 6th Jan 2011 at 18:12
smegal
Post #56
Mab should be able to sort you out.
Does anyone see any issues with replacing the standard lambdas heater with a resistor and using the output from the aem.
Ex SC-6
Now in a Megane R26
Posted 6th Jan 2011 at 18:15
Post #57
why would you do that? just use the 12v+ to power the AEM, earth for the AEM earth, and send the AEM signal down to the ecu down the original signal wire.
Posted 6th Jan 2011 at 18:23
mcfc1987
Post #58
PM sent, I no longer need mine and Mabz said i could get rid of mine if i could find another buyer
Posted 6th Jan 2011 at 18:24
ballardpaul
Post #59
So the White wire just goes to the source wire that the old lambda uses? Any ideas which wire this is?
Posted 6th Jan 2011 at 18:27
Post #60
yeah one of the 4 in the plug connected to the original lambda.
Posted 6th Jan 2011 at 18:29
ballardpaul
Post #61
Thought so. Guessing mabz knows which colour it would be?
Posted 6th Jan 2011 at 18:32
cosmic spanner
Moral objector
Post #62
Actually, I only wanted to ask a question that occured to me over xmas, but I didn't want to derail the thread.. Unsure Since it's all done and dusted, maybe I can ask now..
I see a few of the supercharged boys have bought one, I'm just wondering how you would use this? I know it's a very common thing to have on tuned cars..
I've had my car rolling roaded and I now know the AFR is spot on. OK I know some of the guys have got slightly shakier AFR due to running the later, larger inlet restrictor rings.. would be useful to find out the once, but beyond that..?
Other than giving me something (new) to worry about, how else can I use it? If I did find it was running lean, what can I do with the information at the roadside? Presumably only thing I could do would be to book it in with Wayne Schofield for a remap? I guess if you had a programmable ECU it would be different. And/or an expensive engine build like a high-boost.
God knows I love my shiny things and flashing lights and dials LOL just thinking out loud, really!
C'mon, sell me!
Posted 6th Jan 2011 at 18:53
Post #63
gives you earlier indication if say and injector was failing, or a fuel pump, or boost leak etc, running rich can be as bad as running lean.
further than that only really useful if you wanted to map it yourself, though does help a mapper keep an eye on AFR's, and as they switch much faster than the o.e lambda theory would suggest they'd give better fuel economy if mapped appropriately.
Posted 6th Jan 2011 at 18:52
Post #64
Basicly you can back off the throttle the instant you see a problem, giving you time to find and fix the issue before it costs you an engine (Thats why most of the highly tuned engine boys seem to have one)
I'll be fitting one to my car as soon as it's ready to go. Does your car retain the knock sensor?
Posted 6th Jan 2011 at 19:20
smegal
Post #65
Hmm I didn't thin of that, surely the heater has a specific resistance. Remember that you'd be trying to power the gauge and lambda off the ECU.
Ex SC-6
Now in a Megane R26
Posted 6th Jan 2011 at 20:14
mabgti
NV motors
Post #66
Even on std management it helps for you to understand your throttle position, fuelling, mpg etc etc
As it replaces the OE one its a worthy investment. I've seen guys fit induction kits and lean out their STD management at WOT.. So its more for peace of mind and it looks uber cool tooLOL
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 6th Jan 2011 at 20:15
Post #67
nope, the 12v power comes from the double relay or a straight ignition switched feed.
Posted 6th Jan 2011 at 20:16
cosmic spanner
Moral objector
Post #68
Yes
Posted 6th Jan 2011 at 21:01
Post #69
Yes
Should be fairly safe already then but it does give you some extra warning of impending doom and as stated elsewhere they look uber cool Cool
Posted 6th Jan 2011 at 21:03
mabgti
NV motors
Post #70
i'm gonna knock up a FAQ for fitting on sunday if everyone can hold five till then!
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 6th Jan 2011 at 21:21
ballardpaul
Post #71
Thanks mate. No rush for me as I've got to attempt to make a gauge pod first
Posted 6th Jan 2011 at 22:24
smegal
Post #72
I misread this thinking you were refering to powering the aem from the lambda.
The resistance of the lambda heater is a way of testing it so it could cause errors id the standard lambda is missing.
Ex SC-6
Now in a Megane R26
Posted 7th Jan 2011 at 04:52
smegal
Post #73
I bought mine to replace the standard lambda, as well as having a visual display of AFR.
Ex SC-6
Now in a Megane R26
Posted 7th Jan 2011 at 04:54
ballardpaul
Post #74
Isn't this how Mabz has his running with no problems Smegal?
Posted 7th Jan 2011 at 05:06
smegal
Post #75
He has the standard one wired in (except for the signal wire)
Ex SC-6
Now in a Megane R26
