Author Subject: power to manual steering
turbowagon
i kn ow there is a thread on here some which some one makes a dummy power sttering pump or pulley or a p/s relocation bracket can any one point me in the right direction? thanks
slowest project car ever.com
Posted 28th Nov 2010 at 04:07
midlife
Richw makes themWink
Cool
Team 330™Cool
Team "no front end or engine"
Posted 28th Nov 2010 at 04:14
turbowagon
any ideas where i can find pics or info ? thanks
Posted 28th Nov 2010 at 04:21
midlife
Look in his supercharger kit threads, use the search button
Cool
Team 330™Cool
Posted 28th Nov 2010 at 05:18
turbowagon
that mite be an option that relocation bracket but im putting manual rack in
Posted 28th Nov 2010 at 05:17
turbowagon
maybe if i filled pump with fluid and capped it off it wouldnt seize solid......... any one done manual rack conv on here?
Posted 28th Nov 2010 at 05:28
Sort of, but I didn't have PAS to start with LOL
Down to Halfords for a shorter belt!
Posted 28th Nov 2010 at 06:28
turbowagon
i work for a motorfacors but it doesnt look like the belt would route right with out the ps pulley in the loop
Posted 28th Nov 2010 at 16:43
You might get away with just looping the outlet to the inlet and leaving some fluid circulating.
Or slit the casing and rip the rotor out and blank the ends up.
You'll want to change the valving in the steering rack either for the manual version or by putting a solid stop in to get rid of the flex in the quill, or it'll still feel slightly numb.
Posted 28th Nov 2010 at 17:28
pugheaven
i think you can use the s16 engine mounts to relocate it?
Posted 28th Nov 2010 at 19:51
yep, S16 non aircon mounts are ideal, make a simple adjuster bracket from a 205 aux belt adjuster and some flat bar, and a belt every so slightly longer than a 205 aux non-pas belt.
Posted 28th Nov 2010 at 20:06
