Author Subject: How do I disconnect my alarm
mrcjevans
on my 6, worked out its been draining my battery, im getting me new tax tomo morning and need to give it a long run. Does anyone have a quick tutorial to disconnect the alarm, just till i got the time and monies to sort out a new siren n that... my 6 is phase 2 and completely standard hope this helps
Posted 18th Nov 2010 at 23:04
smegal
Just unplug the siren.
Ex SC-6
Now in a Megane R26
Posted 18th Nov 2010 at 23:38
Remove the passengar side arch liner front trim and put your hand up and disconnect. This can be done easily if you park up on a kerb and put the wheel on full lock.
Failing that remove wheel and pull wheel arch liner back to expose so you can disconnect.
New siren is circa £150 quid so you may want to raid the penny jar. Most second hands ones don't work and even if they do they will soon die.
Posted 18th Nov 2010 at 23:45
mrcjevans
Would it not be easier to diconnect it just by taking out the fuse?
Posted 19th Nov 2010 at 00:41
smegal
Save this search on ebay.
I got a brand new siren for £35 delivered. It was about 4 months until one come up though.
Ex SC-6
Now in a Megane R26
Posted 19th Nov 2010 at 00:56
jeffers Forum Admin
Or take the rear drivers side trimpanel off and disconnect the alarm control box.... mine had exactly the same problems of battery drainage, disconnect here and no more problem!Wink
Team Running Engine again!
Team Negative Camber!
Posted 19th Nov 2010 at 03:00
mrcjevans
Been reading somethin on other forums about some lil box behind the left front light?
Posted 19th Nov 2010 at 04:20
fugs
Jeffers is that the little box inside the quarter panel?
Posted 19th Nov 2010 at 21:59
jeffers Forum Admin
Yep! Wink
Posted 20th Nov 2010 at 05:41
