Author Subject: Weight distrubution!
fugs
I got my car weighed the other day on a scales weighing each wheel. The distribution is shackingly bad. Front right wheel has 390kg but the rear right is only 125 kg. The other 2 wheels are somewhere in between. The car being stripped out may not help this but has anyone any tips on moving weight about without adding any? Get me?
Posted 16th Nov 2010 at 20:20
oecken
try searching bud, but see here, you may need to scroll through the useless posts though LOL
click
Posted 16th Nov 2010 at 20:34
fugs
Ok from what my little knoledge tells me I can move the battery to the rear which will help a bit. Is there anything in around the engine bay which I don't need. Aircon and pump is already gone!
Posted 16th Nov 2010 at 20:39
lotek
battery relocation,smaller washer bottle, relocate pas pump then cut bracket down, lighter calipers and discs. Yes
will help a fair amount
Posted 17th Nov 2010 at 00:29
Denis
You can even out the corner weights side to side by setting the suspension height. My corner weights were (¼ tank of petrol):
FL -- 351 FR -- 356
RL -- 169 RR -- 185
Total: 1062
Cherry Red Rallye Project thread
WhiteBMW M140i
Posted 17th Nov 2010 at 02:26
Yes, the reason is, your car is front-wheel-drive, and front engined. I don't know if you'd noticed? Razz
Posted 17th Nov 2010 at 02:29
Rich E Forum Admin
FL -- 351 FR -- 356
RL -- 169 RR -- 185
Total: 1062
I make that 49.5% cross weight.. Very nicely set up Cool
Posted 17th Nov 2010 at 02:38
Denis
It is! The amazing thing is that it was done with just a tape measure – was a bit of a surprise when I saw the readings on the scales.
WhiteBMW M140i
Posted 17th Nov 2010 at 03:43
Rich E Forum Admin
So the cross weight coming out like that was something of a fluke?! Laugh
Posted 18th Nov 2010 at 01:04
lotek
LOL
looks like il be doing simular with the ralllye LOL
Posted 18th Nov 2010 at 13:51
rob s
This has been something ive wondered about on my standard rallye - wont such a weight distribution (regardless of what the car is carrying) mean that tyre pressures should be adjusted accordingly? i.e. 36 front, 32 rear? Does anyone worry about this?
Rob S
Posted 23rd Nov 2010 at 00:50
crf450
Denis,post some pictures of your car up it looks ace.
Quote "da g man!"
"You've only got to watch the "306 vs ringtaxi" video & you soon realise how good these mod's are! That guy is running Ash's 30mm ARB, Solid Mounts & 23mm Torsion Bars & some adjustments on the camber. Admittedly, the guy is an awesome driver, but it just go's to show how well these cars can handle with the right modification's
Posted 23rd Nov 2010 at 17:40
janne l
A lightweight carbon or fibreglass bonnet will help, I think you save somewhere around 15kg's in just the right place.
That, moving the battery and getting rid of the apparently really heavy slab of sound dampening thats up against the firewall should help quite a bit.
Peugeot 306 GTI -97 Stripped out trackday toy
Peugeot 307 SW Griffe -05
Peugeot 206 1,6 Griffe -04
Posted 1st Dec 2010 at 09:27
Rich E wrote:
FL -- 351 FR -- 356
RL -- 169 RR -- 185
Total: 1062
Until you add a driver Wink still Dennis is'nt exactly a bloater so impressive result all the same. And with a passenger will work nicely too.
Posted 1st Dec 2010 at 19:44
