Author Subject: Track car set up
fugs
Can anyone tell me what is the ideal set-up for a 6 track car. What coilovers? And what spring rating would I go for? I have avo ones but they still seem quite soft. I want to get something very stiff! What about a good arb set up aswell? Any hints on Geo set up?
The car is not for the road so I can go to extremes here!
Posted 15th Nov 2010 at 23:11
KW are a popular choice. AST are also very good and about the same price, but you have a choice of spring rate on those. Guess it depends on your budget - ASTs are about £1000 for single way sportline 1s, and about £3500 for 3-way.
I was running 285 front for a road setup but needed bigger rear tbs really. You'll want the bigger of Ash's rear ARBs. I'd have a good search through here as there is a load of info.
CRF450 (martin), Farmer, Russian Guy (denis), Miles, Ash and Pete_Rallye (please add if i've missed you...) are regular track/race whores. Worth PM'ing them I reckon to ask their opinions.
Posted 16th Nov 2010 at 00:13
fugs
Whats the difference between the single way and the 3 way asts?
Posted 16th Nov 2010 at 20:15
The type of damping you can adjust. I can't remember off the top of my head. Give Curtis (AST UK) a ring on 01684 275000 and he'll be able to answer all of your questions. Thumbs up
Posted 16th Nov 2010 at 20:46
Just a rebound adjuster vs rebound/low speed compression/high speed compression adjustment
Posted 16th Nov 2010 at 20:52
simonjames
i got Avo's with 350 springs im yet to give it an outing though so cant comment on how well it does or doesnt handle
MY EBAY ITEMS
07943066306
Posted 16th Nov 2010 at 21:15
fugs
Simon is it possible to get the springs on there own? I have Avos also. If I could get new higher rated springs I'd be happy.
Posted 16th Nov 2010 at 23:00
cooper666
i have also got avo coil overs they come with 250lb springs as standard i had to fit 325lb springs just to get it to a decent ride deamon tweeks do sell the springs on there own. if your coilovers are the same as mine you will need 2 ¼ diameter springs 8 inch length.
spring clicky
clio r27
ps3 id:cooperkloe
Posted 16th Nov 2010 at 23:55
simonjames
As above tweeks do them i got mine from avo they rebuilt the both front units and put new bump stops on iirc it cost me £160-180
MY EBAY ITEMS
07943066306
Posted 17th Nov 2010 at 00:32
Denis
There is no ideal setup as it depends on too many things, the main been the budget!
When going up in spring rate - in most cases it is necessary to re-valve the dampers to work with the springs.
Cherry Red Rallye Project thread
WhiteBMW M140i
Posted 17th Nov 2010 at 03:40
