displaying posts 1 to 25 of 31
Author Subject: Water in passenger footwell
vernam616
As title basiclly, now im quite aware of what this all points to
However the matrix was changed 4 weeks ago and the car seems to be running ok, allbeit a bit shit on fuel
I was wondering if theres a common place for these to leak in? seeing as we had a very heavy rainpour the other night
Any help appreciated
Audi S3 Black Edition
Posted 14th Nov 2010 at 01:10
smegal
Is that door seal ok?
Also check if water is coming from the A pillar. It doesn't normally but worth a check. Does the water taste of water?
Ex SC-6
Now in a Megane R26
Posted 14th Nov 2010 at 01:14
simonjames
check if coolant is down if not could be the seal where the aircon pipes go through bulkhead
MY EBAY ITEMS
07943066306
vernam616
Coolant has stayed the same me thinks
+ its a Rallye with no aircon Razz
Posted 14th Nov 2010 at 01:19
davidmartin
check that it's bled properly,if the matrix is full of steam it will escape there
pet hate, the cat
Posted 14th Nov 2010 at 01:28
idboo
Had this problem when i first got mine, i took all the door seals off and cleaned all the gunk out that was under them and made sure they were all refitted correct. stopped mine leaking in water....worth a try.Smile
Posted 14th Nov 2010 at 01:33
vernam616
Really? im actually quite worried that i havnt nipped something up where the matrix joins the pipes and im going to have to have it all back out again Sad Doh
Ill try bleeding it tommorow and see what happens, strange because since the head has been doing i keep checking the carpet and its been ok, only today when i checked it was really wet, thinking it could have maybe been the downpour, i really hope it is ..... however in GTI-6/Rallye Land things never are Angry
Posted 14th Nov 2010 at 01:35
vernam616
Thanks, will give it a go tommorow, i had a quick check over tonight, just run my fingers round looking for breaks/rips and they seem perfect Dunno
Posted 14th Nov 2010 at 01:36
davidmartin
had it happen when I done the derv not long ago,it's been fine since I used a larger header tank LOL
pet hate, the cat
Posted 14th Nov 2010 at 01:40
had massive trouble with this on loads of my 306's \ 6's... water collects in the bottom front corner of the door sill fills up the inside squidgy bit of the seal and then comes in the footwell. Also could be blocked door drain holes. Another thing can be if someones had the door card off e.g for a new window regulator they may not have put back all of the seals that cover the holes in the door. Water runs down the window and down the inside of the door card.
All this is providing your heater matrix is ok of corse... Wink hope it is because i've been there before and had to take the whole lot out again as i managed to crack one of the pipes that goes through the bulkhead Sad
Posted 14th Nov 2010 at 15:48
dan86
Take the passenger speaker grill off and unscrew the speaker. Check that there is a piece of plastic/foam behind the speaker to deflect any water that drops down inside the door. Without it or if it is damaged water will land on the speaker magnet and run down inside the door panel then into the footwell. I've had 3 306's with this problem as previous owners had put aftermarket speakers in and torn the plastic/foam. Worth checking as it's only 3 screws?
Posted 14th Nov 2010 at 15:53
vernam616
Thanks, ill try this, mine does have aftermarket Alpine ones in
Posted 14th Nov 2010 at 19:15
dan86
Did you get to the bottom of this problem?
Posted 21st Nov 2010 at 02:44
vernam616
Funny you should say, as i was about to update, your theory was very much correct, as it had rained this morning, i had a check and sure as shite, it was coming in from the bottom of the speaker cover LOL
Thanks Thumbs up, will have to find a way to solve it
Posted 21st Nov 2010 at 02:47
dan86
Glad I could help! Thick polythene and double sided tape should do the trick.
Posted 21st Nov 2010 at 03:02
GTI-6
Hey folks,
My 6 is filling up the passenger footwell with fluid. It isn't coolant.
It is coming through the bulkhead gromet. There is a power lead running through the gromet for an amp.
Question is, is there an easy way to repair this? I assume its the aircon drain pipe...
Looks like it could be a pig of a job....
Love thy 6
Posted 25th Dec 2012 at 09:23
aaron6
I'd just use silicone. Wink
Posted 25th Dec 2012 at 09:32
mellowr1
i have just been out to mine to try and stop my door rubber filling up then running into drivers wellUnsure
Fitted a new wrench rubber,fitted plastic sheet behind speaker so il see what happens now.
oddly enough when its jetwashed it doesnt happen,its only when the cars sat and it rains hardDunno
Poxy french crapThumbs up
Posted 25th Dec 2012 at 09:52
aaron6
I always slit the seal a little. It seems to allow the rain water to drain out of the seal okay. Smile
Posted 25th Dec 2012 at 12:15
mellowr1
If all else fails i shall do that but think it defeats object of sealUnsure
Passenger side does not do it so drivers side shouldnt.gotta b a seal somewhere not quite right m8Dunno
Posted 25th Dec 2012 at 20:19
osm2121
You can also check in this places i pointed out in the picture. In both sides, theres a little drain hole in the bottom, and when its clogged, that place fills up with water untill it starts getting in somewhere through the firewall. Try pouring somewater there, and it should get out behind the wheel, if nothing comes out, you need to unclog the drain hole. Hope it helps, and that you understand my primitive english Dunno
Posted 25th Dec 2012 at 20:51
I find you need to remove the door seal and squeeze it back together where it connects to the car, then re attach the rubber the car using a piece of wood and hammer to get a really good seal Thumbs up
Always sorted the problem with many of my 306s Yes
Also check the seals at the bottom of the window are good and deflecting water away from the glass Thumbs up
Posted 25th Dec 2012 at 21:20
fast_eddie
Is this a similar issue when screen wash water comes in through an open drivers door window when travelling, or is this just a design fault?
Posted 25th Dec 2012 at 21:28
rich306
Design fault i think buddy, every 306 i've had has done it lol. You eventually learn to have it part the way up or clean window when stopped Big grin
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 25th Dec 2012 at 22:10
GTI-6
I blew it our with air at work, loads nasty s**t came out, but it runs directly from the gromet, so Im guessing the air con drain pipe got punctured putting a hole in for the power cable to run through.
I might just fill it with silicone as the guy above said
Love thy 6
Posted 26th Dec 2012 at 11:00
