Author Subject: fitting vts torsion bars
jord294
hi guys
i'm after a little help please
i will be fitting eibach springs to the front of my car and am also overhauling the rear beam, and fitting 21mm torsion bars
is anyone running the same set up? if so, can you tell me what the distance was between the shocker bolts
thanks Smile
Posted 13th Nov 2010 at 22:23
davedgti6
I have this set up and lowered the ream beam to suit after refurbishing it, the bolts "I think" are normally 330mm apart so to lower it 30mm the same as what the Eibachs are supposed to the bolt measurement would be 310mm,
However when I set mine to this it was a bit high so I lowered it again using this method,
http://www.306gti6.com/forum/showthread.php?id=63880&page=1
Mine on Eibachs was 605mm from the floor to the bottom of the arch so I set the rear distance to the same measurement Smile
Posted 15th Nov 2010 at 00:13
jord294
that's good to know. thanks
i was gonna go for a measurement of 312mm anyway
Posted 15th Nov 2010 at 01:04
Denis
I have not measured the bolt to bolt centre, but when fitting the 21mm bars I had to lift the trailing arm by about 25mm to get the same ride height as before.
Cherry Red Rallye Project thread
WhiteBMW M140i
Posted 15th Nov 2010 at 02:31
jord294
that sort of makes sense.
i've only recently found out that the bigger the torsion bars, the less the measurement between the shocker bolts needs to be
it makes sense. as there is less 'give' in thicker bars
Posted 15th Nov 2010 at 02:35
jord294
well i've fitted the vts torsion bars, with a measurement of 311mm between the shocker mounts
also fitted the eibachs to the front.
i've taken measurements roughly from the sill to the floor.
at the front of the car i have a measurement of 140mm and the rear part of the sill is 160mm
so the car does sits lightly higher at the back
which i believe is how it should be, and should not be sitting level
Posted 17th Nov 2010 at 00:08
sounds just about right Andy, that's exactly the rake front to back that the rally build book states for both the 205 and 309 Smile
Posted 17th Nov 2010 at 00:21
jord294
nice one Big grin
will tighten everthing up next time i'm off work
Posted 17th Nov 2010 at 00:25
Denis
That is how my track car and standard GTi seats as well Wink
WhiteBMW M140i
Posted 17th Nov 2010 at 02:20
jord294
job done Big grin
the final measurement was 308mm between shocker mounts, and eibach springs fitted to the front
Posted 2nd Dec 2010 at 00:16
+1 (when I had it...) The impreza sits a bit more than that, but it needs all the turn-in help it can get.
Posted 2nd Dec 2010 at 17:39
gaz likes shmeat
looks spot on. thats the exact ride height i'm wanting mine to be.
Posted 2nd Dec 2010 at 17:42
clen666
+1, handy bit of info here cheers
Team 'unintentional rat look'
Posted 3rd Dec 2010 at 17:46
matt evans
jord294 wrote:
job done Big grin
Andy, what profile tyres are on your Nile?
Did the ride height come out the same both sides when you did it this way?
Ta
honestly3k wrote:
owain wrote:
Posted 9th Feb 2011 at 00:05
matt evans wrote:
jord294 wrote:
job done Big grin
Ta
The WRONG profileLOL
50'sWink
Posted 9th Feb 2011 at 02:03
