displaying posts 1001 to 1021 of 1021
Pages (41): first .. 39 40 [41]
Author Subject: Harris' SC China Track Car attempt
scotzman
Post #1001
I'm sure a grinder can sort those clearance issuesLOL
Posted 6th May 2014 at 10:46
eddy_gti6
Post #1002
Why do they sit so far off the disc? Can you not machine the bracket down so they fit better?
Posted 6th May 2014 at 10:57
Post #1003
Laugh
Thats what I was thinking. Just shave a bit off the inside of each wheel spoke Whistle
No idea, ask KAD? Laugh
Posted 6th May 2014 at 11:27
scotzman
Post #1004
The pads are only contacting the outer 3/4 of the disc
Posted 6th May 2014 at 11:38
eddy_gti6
Post #1005
What size discs are you running?
Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url &amp; =
Posted 6th May 2014 at 11:44
Post #1006
Yeah I know, were like that from when I got them (second hand). Will PM the previous owner to see what he knows about it all.
Cant remember Laugh
Pretty sure they are standard sized though?
Posted 6th May 2014 at 11:54
tvrfan007
Post #1007
Common for these sorts of brake kits to compromise disc contact to fit a caliper. Not fitted mine yet though so cant comment lol.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 9th May 2014 at 17:45
Post #1008
Right, so I've bought some 3mm spacers for the front wheels to hopefully clear the brakes when using cyclones. Will I get away with using standard bolts as its onlt 3mm, or will I need longer ones?
If I do need longer bolts, does anyone know where to get them from?
Thanks,
Posted 14th May 2014 at 10:28
eddy_gti6
Post #1009
Should be fine. Sure I ran 5mm on standard wheel bolts on 1 of my old cars with 16s over brembos
Posted 14th May 2014 at 15:22
Post #1010
Another small update:
Wheel spacers turned up the other day so need to do a test fit for cyclones and measure bolts etc to see if I will get away with 3mm spacers and standard bolts.
I removed the 3 coolant sensors off the thermostat to get replacements for all of them. While they are out, I taped up the holes on the 'stat housing, but does this now mean I will have air in the system and need to do a quick bleed up afterwards? (appreciate this may be a very silly question??)
Also bought a carbon bonnet badge that Gnrlee did, and after a lick of paint fitted it on. I realise now I shouldnt of masked off all the inside, as that needs doing too Doh
And finally I bought a Leon Cupra R splitter off a mate. Brand new in box, but still unsure if I want to use it. I have seen it on a few 306's and quite like it tbh, but still a bit unsure.
Posted 19th May 2014 at 12:14
superchargedblack1997gti6
Post #1011
I managed to fit the discs and kads under cyclones with no spacers looks to me like you're discs are the different though Sad
Posted 19th May 2014 at 12:31
Post #1012
Yeah I knew you had them under cyclones Ross and thought you said there was no spacers Hmm
Do you know what discs you had fitted there? Smile
Posted 19th May 2014 at 13:25
Post #1013
Few little bits done..
Got all 3 temp sensors for the thermostat housing.
Went to fit them, got two sorted but the blue one only seems to have 1 pin, rather than 2.
I checked this with CAS as my original sensor has 2 pins, and the connector has 2 pins. They double checked and cross referenced it etc, and it should have 1 pin now. Something to do with a revision? Can anyone shed any light on this?
Will fit it and see how I get on I guess Dunno
Then started on some rust removal. I have decided at some point, I will get the engine out so I can get it all done properly, and cut out bits if they are f**ked etc, but for the time being, just some simple stuff to make it look a bit more presentable, and to stop the rust getting worse.
I have started on the passenger side inner wing.
Here is how it was when I started
After a quick going over with a wire brush etc to remove the majority I was left with this.
I then set the Deox-C gel to do its magic. Used some small bags to apply to stop me covering myself in it, and then left it on to try and stop it drying out too quickly.
Came back to this, it does work well, and saves a lot of effort.
Will finish that off, then give it a coat of red oxide primer, and a quick lick of paint before FCS.
Posted 29th May 2014 at 13:19
walker_texasranger
Post #1014
Chris,
I replaced the coolant sensor on mine at Christmas as it was reading as though it was on fire at 70mph Cool
The one supplied came with 1 pin but after sending it back and specifying two pins, one duly arrived, thats as much as I can tell you LOL
Hilux InvincibleX daily
306 No.13 Doh
Posted 29th May 2014 at 15:45
Post #1015
Few more bits and bobs done...
Firstly, finished off my inner wing tidy up (for now)
Bit more presentable, and hopefully stop the rust getting much worse.
Then cleaned up the earth points and connectors.
Managed to get a Leon Cupra R splitter for cheap off a mate, so decided I would fit that. I fancied a bit of a change, but now fitted I'm not too sure. Some angles I like it, some I dont.
Bit of bending and cutting needed, but all easy stuff and got it done in about 10 minutes.
I'll let the pics do the talking..
And fitted...
Posted 4th Jun 2014 at 09:41
Post #1016
Just bung the original sender back in, if it aint broke dont fix it...
you wont have a high temp warning light with a single pin unit and it should not cross reference.
Posted 4th Jun 2014 at 10:04
Post #1017
It is broke though. The sensor I had in over reads (well, it seems to do what it wants to be honest) Laugh
Posted 4th Jun 2014 at 10:13
Post #1018
over reads in reference to what though? or is it the new one under reads...
Posted 4th Jun 2014 at 10:47
Post #1019
The one that was in it, (2 pin) will start showing that the car is overheating. For example, last week I started the car from cold, walked off for a minute, came back and the temp on gauge in car showed about 100 degrees. This is not the case, all the hoses and rad etc were still stone cold (as they should be after a minute of running from cold).
The temp doesnt stay like that though, gauge shows that the temp drops again (with no fan assistance to do this), then it will rise again. Seems to do what it wants, so there is no way of me knowing how hot the water actually is.
Posted 4th Jun 2014 at 12:10
eddy_gti6
Post #1020
Good work on the chassis leg mate but not a fan of the cupra splitter
Posted 4th Jun 2014 at 18:28
99rallye
Post #1021
How is this coming on? Still got it Chris?
Posted 26th Mar 2015 at 21:51
