Thanks
Team V6
| Author | Subject: Fuel pump relay location |
shimmy
Senior User Location: Shrewsbury Registered: 17 Oct 2009 Posts: 571 Status: Offline |
Does anyone know? Thanks ________________________________________ Team V6 |
CUJ
Seasoned Pro Location: Southampton Registered: 18 Apr 2006 Posts: 22,218 Status: Offline |
Pretty sure it's usually found attached to the back of the battery box?________________________________________ 340 horses |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
Bolted to back of ECU/ battery box! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
shimmy
Thanks chaps, bit of a short first post, using a mates phone that is impossible to work.Thanks again ________________________________________ Team V6 |
You've got two relays the same in your car now One runs the fuel, the other the coilpack iirc. If you aren't getting power to the fuel pump its either:1. immobiliser issue, but shouldn't be as you've got an unlocked ecu 2. you've blown the ecu up 3. dodgy wiring ________________________________________ Nothing to see here |
shimmy
I think the fuel pump is working.Was idling for a few minutes then conked out and now won't start again. What else could it be? ________________________________________ Team V6 |
Coilpack. Crank sensor....?________________________________________ Nothing to see here |
run out of fuel? ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
shimmy
Well, the light was on so it went to the petrol station and had £15 of the finest . Then 10 minutes later nothing.Okay il investigate anything else. Didnt you have new coilpack on yours? ________________________________________ Team V6 |
shimmy
Think its been narrowed down to the crank sensor, any idea of price of a new one?________________________________________ Team V6 |
£15 odd from GSF.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
shimmy
Just bought one from my local auto parts place, be there 1.30ish £19 so not bad. Whats the canister thing attached behind the tb?________________________________________ Team V6 |
idle valve ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
shimmy
Changed the crank sensor and still wont go, any other ideas?________________________________________ Team V6 |
What ECU are you using?________________________________________ Nothing to see here |
shimmy
Yours, i have an unlocked one aswel, tried that and still nothing?________________________________________ Team V6 |
