Author Subject: Gaskets
daver6
Hello there, turned out my CAT didn't have a hole, it was the gasket between the manifold and the cat that had gone.
My mate at Kwik-Fit gave me the Diesel kit, didn't say which model, but I would imagine it would cover Dturbo and HDI. So, the question is, will this gasket and spring set-up for on the 6?
Wishbone Polybushes available
Posted 10th Nov 2010 at 13:56
probably not, I'd just go an buy one from a pug/citroen dealer.
Posted 10th Nov 2010 at 23:09
miles
£25.00 ish from the dealer, Much better than any other factor rubbish you get which tend to fall apart in a few months
www.pugracing.com
Posted 11th Nov 2010 at 02:05
woody.
Part no. 1798 75
You can buy them from peugeot or citroen for £20.88
Posted 11th Nov 2010 at 04:01
lotek
mine was from Kwik Fit And has been fine Yes
3 trackdays later and its still going Strong Dunno
As far as im concerned it will only fall apart if you have excessive movement, ie worn mounts.
Posted 11th Nov 2010 at 20:41
mikebee
Actually I'll +1 on this as mine is blowing.
Attempted to get the current sprung bolts apart at the weekend. The driver side one was okay as I could get a spanner on the back, but the other one is a nightmare for access.
Does anyone have any tips for this? The FAQ just says 'you need to have a play'. Unless I chop half my hand off I can't see how I'm meant to get in there???
Posted 15th Nov 2010 at 17:50
i find the drivers side one more tricky tbh, get in from underneath or around the subframe.
Posted 15th Nov 2010 at 17:56
mikebee
it does seem tricky. the problem i have is the bracket for the gear linkage is bang in the way of where i need to move my hand for the passenger side one!
will have another go at the weekend. doesn't help not having a set of ramps i guess.
Posted 15th Nov 2010 at 18:39
daver6
I'll have the benefit of a ramp either at Kwik fit or at work. I'm going to try this gasket it out, if it works I've saved money, if not then at least I'll have wasted my time haha.
I'm sick of having to wait for Poogeot to get parts in stock.
Posted 15th Nov 2010 at 20:34
woody.
I had a mate help me out but did have the car on ramps. It's tricky but you can do it, eventually!
Posted 8th Dec 2010 at 01:02
daver6
Just got my mate to order it through Kwik-fit, literally a two minute job... can't believe it was the police's vehicle defect form that prompted me to sort it haha
Posted 3rd Jan 2011 at 20:22
