displaying posts 1 to 25 of 39
Author Subject: KAD 6 pots fitted!
chrisd306
im just trying to fit my brakes,well see how hey go, does this look right?
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 12th Nov 2010 at 03:10
gti6girl
Think thats right mate
Posted 8th Nov 2010 at 15:35
can't see the car Huh?
Posted 8th Nov 2010 at 15:42
chrisd306
ive not got the car ready to trial fit them, but i was just trying to work out if thats how they went.
& Audi Q5 S Line
Posted 8th Nov 2010 at 15:48
Its upside down isn't it?
Posted 8th Nov 2010 at 19:01
chrisd306
shouldnt be as it loks like thats how it was as the dowel was left in on 1 so it ment it had to go that way on caliper if you know what i mean
& Audi Q5 S Line
Posted 8th Nov 2010 at 19:16
Should be right provided that's the nearside caliper?
Posted 8th Nov 2010 at 21:37
chrisd306
Tryng to fit these am no matter how I try to fit them they go tight on the disc, in my first pic is that right for the two spacers to fit against hub? As when it's like the the discs hard up against out side of caliper, then vice versa with out spacers?
I'm thinkng either hub has to be skimmed slightly as has a shoulder that would let disc on far enough not to rub in first position
Or a spacer to shim the disc out a ball hair then wouldn't rub in postion 2!!
This set up was removed fom a 6 so should fit, will be somehing simple I'm sure, anyone got a number for bunks with turbo'd 6? If so get him to reply in this thread lol as I'm stuck now lol plus it's to cold!! Pics to follow
& Audi Q5 S Line
Posted 10th Nov 2010 at 22:50
chrisd306
Where does this go? between hub and bracket? thats where i think it does,
This right?
it looks like the discs dont fit over the lip so im thinking i can grind this flush and it should be ok as if disc could go further in it wouldnt rub the caliper.
asked binka, and colin at pug performance cant remember if they had to do anything to fit these, i think they must off had to, as me and another dude are having similer problems.
its focus rs discs im using as thats what binka used.
any ideas chaps
& Audi Q5 S Line
Posted 11th Nov 2010 at 02:31
if the RS discs are new then they would need the centre hole taking out to fit the peugeot flange.
Posted 11th Nov 2010 at 02:34
chrisd306
no there used everything is used all been fitted to a 6
this is as far as the disc goes on.
& Audi Q5 S Line
Posted 11th Nov 2010 at 02:43
rallyeash
not on far enough should be another few mm?
309 3dr K20 Type R
Posted 11th Nov 2010 at 02:51
chrisd306
yes i know that, but it wont get over the lip on hub, in pic 3 in other post, should i just rub it down a bit and rub the discs down a wee bit an it should go?
im thinking thats what they had to do at pug performance when they fitted them to binkas.
& Audi Q5 S Line
Posted 11th Nov 2010 at 02:58
berger
Sounds like a bodge to me.
Have the bore of the discs altered and rechamfered to suit instead and they will go straight on.
Bang'in 7 gram rocks!
I have one gear, GO!
Posted 11th Nov 2010 at 03:22
what he said!
Posted 11th Nov 2010 at 03:32
chrisd306
would be better buying new discs to do that to tho, will neede to try get the boy to check his hubs see if they have the lip
& Audi Q5 S Line
Posted 11th Nov 2010 at 04:09
mabgti
NV motors
just get them bored out as required.. kad brakes dont usually utilise shims... but i believe they were used for wheel clearance hence the disc change..
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 11th Nov 2010 at 06:27
chrisd306
Itis fouling on the two lugs thats used for bolting the calliper to,been playing about, and i either need half the size of small washer for bolting on and a 5mm spacer for behind the disc or probly just a 3mm spacer for behind the disc should see it alright as got it lined up and on, soim trying to find a 3mm spacer to borrow!
& Audi Q5 S Line
Posted 11th Nov 2010 at 18:02
gti6girl
I fitted these on binkas car, you have it wrong, they fit perfectly...pm me your number
Posted 11th Nov 2010 at 18:03
chrisd306
& Audi Q5 S Line
Posted 11th Nov 2010 at 18:08
chrisd306
pm'd mate
& Audi Q5 S Line
Posted 11th Nov 2010 at 23:16
midlife
chrisd306 wrote:
Flicking V's at your hub won't helpWhistle
Cool
Team 330™Cool
Team "no front end or engine"
Posted 11th Nov 2010 at 23:26
chrisd306
haha foyc wayne!
& Audi Q5 S Line
Posted 11th Nov 2010 at 23:49
midlife
Laugh my ass off
Team 330™Cool
Posted 12th Nov 2010 at 00:10
chrisd306
fitted but not quite right, dont rub or that but not how they should be fitted hopefully have some instructions for correct fitting tomorrow.
& Audi Q5 S Line
Posted 12th Nov 2010 at 00:41
