Author Subject: dangerous handling
robbo21
hi peeps, praying here someone can help! My 6 has become dangerous around right hand bends of any angle at any speed. It behaves as if i'm pulling the handbrake on whilst going through the corner, throwing the back end out completely. I found this out on a gentle right bend at twenty mph. I have been to an industrial estate tonight to test that the corner it happened on may have just been greasy but it is happening on any right hand bend. The brakes are not stuck on, all drop links and ball joints and track rod ends have been replaced within the last month and i've checked that none are loose. There is a knock whilst turning the wheel to the right when moving. Please please help! If anyone has any ideas i will be eternally grateful
Official diagnosis: Carpocondria - The persistent conviction that one's motor vehicle is or is likely to become ill
Posted 5th Nov 2010 at 01:23
george23
Is the knocking noise coming from the front or the back? just to try and aid people who will know more than me and be able to help!
Posted 5th Nov 2010 at 01:48
one of many things really. beam mounts,loose arb loose wheel oval hub and etc by the sound of it it might be your mounts but.......wouldn't explain the locking up theory
Posted 5th Nov 2010 at 01:51
cwspellowe
Who said anything about locking up?
+1 for rear beam mounts, most likely the forward pair of the four mounts. I had a spin at about 20mph when my mounts were knackered Yes
Bye bye Sundance Kid Sad
Posted 5th Nov 2010 at 01:59
honestly3k
Wheel bearing fubar'd?!
"pulling the hand break" locking up LOL
Posted 5th Nov 2010 at 02:03
robbo21
sorry guys, the knocking noise comes from near side front. It's not all the way round the lock, just one loud clunk about halfway to right lock. Is there an easy way of checking the rear beam mounts as i can get access to a ramp tomorrow morning. Thanks for all the advice by the way
Posted 5th Nov 2010 at 02:14
sixysix
Check your front springs before anything else Smile
Take a look
Posted 5th Nov 2010 at 02:37
cwspellowe
He didn't mean literally locking up Laugh my ass off
I too have a clunk I need to investigate tomorrow, but it only seems to do it with the whole weight of the car so dunno how i'm going to replicate it.
As another note, check the strut top mounts too Wink
Posted 5th Nov 2010 at 03:01
robbo21
i had checked the front springs yesterday when i was checking strut tops to find the source of the knocking. They weren't broken and were seated properly. I think the rear mounts are a crackin suggestion as the handling has felt a little bit 'wobbly' over the last month. The back end hasn't felt planted for a while now, so will check them tomorrow. Thanks for everything guys, have got a good idea of what to check tomorrow
Posted 5th Nov 2010 at 03:02
Could also be beam bearings making a trailing arm move around and give you random camber.
The clunk could be a driveshaft or top mount.
Posted 5th Nov 2010 at 13:09
robbo21
I've just checked strut top mounts and they're fine, no movement in driveshafts and no play in rear bearings so have got both sets of rear beam mounts for 30 quid all in from local motor factors. Will fit them tomorrow morning and hopefully things will have improved! If not i'd better start watchin tokyo drift and take notes on how to drive it as it is
Posted 5th Nov 2010 at 17:17
