displaying posts 1 to 2 of 2
Author Subject: brake pad warning light
dan164
just done discs and pads all round as pad wear light was on when braking, front were pretty much on the metal so low pads was the problem. however coming home from work tonight its doing the same, light coming on under braking. fluid level is fine, think i may have nicked a pad wire, will unplugging the wires put the light out or do i need to bridge the pins out?
cheers
Posted 4th Nov 2010 at 06:19
jeffers Forum Admin
Just unplug the cables should do it! Wink
Team Running Engine again!
Team Negative Camber!
Posted 4th Nov 2010 at 12:50
