Author Subject: Reinforcing the top strut fixinf
gtylerroberts@manx.net
Does anyone know of a reinforcement that can be fitted to the shell where the front struts affix?
I am a bit concerned that given the agressive surface of the forest stages the existing fixings may not be adequate
Thanks
Posted 1st Nov 2010 at 22:45
Weld a plate under the strut tops?
Posted 1st Nov 2010 at 23:00
midlife
The strut top skin thickness is 3mm, you could weld a plate over the top if your worried about it. TBH I'd put a strut brace on it & consider extending the roll cage to the strut tops.
Cool
Team 330™Cool
Team "no front end or engine"
Posted 1st Nov 2010 at 23:44
Thanks guys,
I have a strut brace that I was adding anyway. just not sure how much abuse a 3mm top would take. Does anyone here have a forest spec 306 rally car that could advise?
Posted 2nd Nov 2010 at 04:09
Not a lot, I've bowed mine on the daily before!
Posted 2nd Nov 2010 at 05:05
205's run with 3mm or 4mm plate welded ontop usually.
Posted 2nd Nov 2010 at 23:27
jonnie205
weld a top plate on, pretty essential realy, continuous seam weld the outer seam and also drill holes in the plate and plug weld into the top mount, then use a strut brace
Posted 3rd Nov 2010 at 00:07
Time to get agricultural on it's ass mate...
Posted 3rd Nov 2010 at 22:13
