Author Subject: Brake lights when clutch depressed
cwspellowe
As above really, noticed tonight evey time I press the clutch the brake lights come on, then when you let the pressure off slightly they go off again. From what I can figure out it's as if the pedal box is moving and the switch makes contact, only happens with the clutch as that requires more force to depress than the throttle.
Where are the mounting points for the pedal box? guessing there's a bolt or two through the bulkhead, am thinking maybe I took a nut off when removing the dash and forgot to pop it back on?
Bye bye Sundance Kid Sad
Posted 31st Oct 2010 at 05:00
It'll just be a little of the force transfering through the pivots, a little WD might sort it for a short while but the problem probably lies with the brake light switch being a little worn - it wants winding out a bit.
Posted 31st Oct 2010 at 05:21
cwspellowe
bo***cks, dash out job? Only just put it back together last week Dry
Posted 31st Oct 2010 at 05:22
It's fiddly but you can just get it from behind the steering wheel surround/clocks if you take them off.
Posted 31st Oct 2010 at 05:29
