displaying posts 1 to 25 of 51
Pages (3): [1] 2 3
Author Subject: Engine Idling at 2k rpm **HELP PLEASE**
:: blade ::
hi all, the pug has been performing fine for a change for 2 months, but friday last week it decided it didnt want to play ball, and is now idling at 2k doesnt decrease if i press the clutch in or anything, i have changed the ICV for a working one and reset the ECU, but it hasnt fixed my problem, just wondering what else would cause this?
cheers
Black Ph1 XSi-6
161.8BHP (Getting Better!!!!)
Posted 25th Nov 2010 at 01:12
kyleey2k
maybe a faulty temp/air sensor? coolant sensor?
Posted 26th Oct 2010 at 00:01
SteviePut
Air leak maybe?
Posted 26th Oct 2010 at 00:14
:: blade ::
hmm will have a look inamin, should hear a hissing shouldnt i if there was an air leak?
Black Ph1 XSi-6
Posted 26th Oct 2010 at 00:17
:: blade ::
checked sensors and they are fine, and i cant find an air leak anywhere :s still confused
Black Ph1 XSi-6
Posted 26th Oct 2010 at 02:14
craigm
A bit basic but have you checked that your throttle cable is stuck/jammed
6 Project Coming Soon Smile
Posted 26th Oct 2010 at 18:01
ben306
+1
My 306 Rallye Project Thread
Lap of Anglesey Coastal
3 sisters circuit
Few laps at Blyton
Posted 26th Oct 2010 at 18:02
:: blade ::
Throttle cable is fine, as its happend as i was driving. I have taken it off and turned it on and the high idle was still there. I unplugged the MAP sensor with the engine running, and the idle cured itself, changed the sensor with another one. And still no change, have unpdone the battery so will leave that for abit and see whats what then if its not, what else could it be? Cheers
Black Ph1 XSi-6
Posted 26th Oct 2010 at 22:27
:: blade ::
change map sensor, and had the battery off for about an hour or so, and its still the same.
Black Ph1 XSi-6
Posted 27th Oct 2010 at 00:42
oecken
Mine did similar, it would idle high, then when upto temp would go between 1k and 2k, and hold the revs while driving, it turned out to be an sir leak from 2 cracked pipes, I couldn't hear any airleak myself.
Posted 27th Oct 2010 at 00:48
:: blade ::
ahh right, what pipes were they if you can remember? as mine drives fine, only goes up once stopped.
Black Ph1 XSi-6
Posted 27th Oct 2010 at 00:50
:: blade ::
Stil cant find the prob, any other ideas?
Black Ph1 XSi-6
Posted 30th Oct 2010 at 23:30
306andy
Faulty Throttle Postioning Sensor?
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
xbox Live tag: SilverGTi6
Posted 31st Oct 2010 at 00:18
:: blade ::
Reet still not found the prob, but i now think its something to do with the ICV, checked the vacume pipes and all was well. So i thought i would check the icv again so i had the car running took the breather filter off the icv pipe and with it idling at 2k i put my had over the pipe and the idle cut down, so unsure as the whats goin on, will change the icv again tomorrow, but has anyone got any final ideas?
Black Ph1 XSi-6
Posted 18th Nov 2010 at 01:59
:: blade ::
well changed the ICV after cleaning another one, and still no change, here is a vid of my findings, if you have an idea please tell as its doing my head in now Sad
clicky to the vid
Black Ph1 XSi-6
Posted 19th Nov 2010 at 01:46
had the inlet off at all recently? no backfires at all?
Posted 19th Nov 2010 at 02:08
:: blade ::
nope inlet not been taken off, but i will be soon as ive got a ptfe gasket to fit, and now backfires, drives fine and pulls well, its just the idling thats the prob :S
Black Ph1 XSi-6
Posted 19th Nov 2010 at 02:10
mattgti6phase2
It's 1million % the icv I have taken mine out and cleaned it twice since owning the car and every time u clean it and put it back in and reset the ecu it just seems to do the same at some points mine was ticking over at 4k from cold then hunting between 800 and 1200 rpm as I said even tho it was cleaned and ecu reset, be patient and let the ecu adapt to it again it takes a few days but I promise it will settle itself hope this helps Smile
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 20th Nov 2010 at 16:30
:: blade ::
New icv purchased so will update that once u have recieved and fitted Smile
Black Ph1 XSi-6
Posted 22nd Nov 2010 at 00:48
:: blade ::
right, getting royally p*****d off with this now, just fitted a brand new ICV and it is still idling at 2k, whats the other options?
Black Ph1 XSi-6
Posted 25th Nov 2010 at 00:54
mattgti6phase2
Where u from fella???
5 x a 306 owner!
Posted 25th Nov 2010 at 03:11
:: blade ::
manchester, so about a 2 and a half hours drive from you Smile
will give it a few days for the ICV to set itself wether that will do anything or not i dont know, was just told it took a few hours driving for the icv to sort itself on a mates car when he fitted one.
Black Ph1 XSi-6
Posted 25th Nov 2010 at 03:14
mattgti6phase2
Bit of a drive then Haa!! If that fails then the only thing I can suggest is to get the fault removed from the ecu as it may have stored the fault, other that have you adjusted your throttle cable at all? Mine was slack when I bought it so I adjusted it on the adjuster by the tb but it has to be just right otherwise it will idle high no matter what you do.
5 x a 306 owner!
Posted 25th Nov 2010 at 13:05
:: blade ::
think im going to be getting put on a diagnostics machine on saturday hopefully, and have it checked and see what comes up Smile, got 50miles to do tomoz so that should put the icv to pace.
Black Ph1 XSi-6
Posted 26th Nov 2010 at 00:27
mattgti6phase2
Good luck with it Smile
5 x a 306 owner!
Posted 26th Nov 2010 at 00:36
Pages (3): [1] 2 3
