Author Subject: Creaky dash
monkgti
well lads, my car was nice and quite (well as quite as you can expect from a pug) LOL until a few weeks ago when a creaking noise has come into the passenger side dash, it was very light but is gradually getting louder and more frequent Angry its not the glovebox door and ive checked all the bolts holding the dash in place and there all thight but if i press hard on the dash just below the airbag when driving it stops.. how does the air bag on that side come out as it sounds from around that area, ive checked the dash removal in FAQ but i cant see any instructions on removing the airbag... has anyone else had this problem?
Any help or ideas greatly appreciated as its getting really annoying now Crazy
IF YOU CAN READ THIS IM STILL IN 5TH!!!
Posted 21st Oct 2010 at 06:30
tvrfan007
Airbag nuts are on the back, accessible from the glovebox space. They're funny triangular nuts iirc.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 21st Oct 2010 at 12:14
tvrfan007
I'm Si btw Tee hee
Posted 21st Oct 2010 at 12:17
justinaccurate
Might it be the glove box? Mine is contantly making noise...
Posted 21st Oct 2010 at 12:30
oecken
i thought that was just french charm? group N engine mounts dont help my cause Doh
Posted 21st Oct 2010 at 14:32
monkgti
thanks for the quick replies lads Wink
def not the glove box because if i open that and even open it and hold it when driving the noise is still there! yeah how is the glove box removed? i opened it and pulled it down past where it stops but the right hand corner of it wont budge and i dont want to pull it too hard incase it breaks! i took out the little screw down the left hand side but it didnt do anything...
Posted 21st Oct 2010 at 14:46
joe5y
I've got the same problem although I have cured it with MUSIC LOL
Seriously though, I would like to find out how to stop this bloody annoying noise!Dry
Joe5y
noaki wrote:
im sorry i wasn't aware 306gti6.com was a cult
LOL
** Team: EX-GTI-6 ** Team: EX-Phase 3 ** Team: EX-Black!
EX owner of a 1999 Peugeot 306 GTI-6 in Black
2006 VW Golf GT-Tdi 170 in Black
1996 Fiat Coupe 20V Turbo In Red
2005 Mitsubishi L200 Warrior in black, chipped with bigger wheels.
2007 Vauxhall Vivaro in Navy blue with alloys and lowered
Posted 21st Oct 2010 at 14:47
oecken
mine has the glovebox rattle, but also centre consle where the 2 parts join together, just above the ashtray... but music helps. Razz
Posted 21st Oct 2010 at 15:58
gaz likes shmeat
i'm sure i must have solid mounts on mine cos my entire interior seems to rattle like a c*nt
Posted 21st Oct 2010 at 16:20
oecken
you would def know! even on start up it was a mental difference.
Posted 21st Oct 2010 at 16:26
My airbag came out by removing the head unit then undoing a nut to the left, then i think you have to pull on a spring loaded pin or something, the airbag should then come out at the head unit side.
It might be best to disconnect the battery first incase you possibly set off the airbag.
Since i changed my heater matrix my airbag is creaking a bit over small bumps so i'm going to have to sort it out, i can hear it over my exhaust at low revs and it annoys the hell out of me LOL
Posted 21st Oct 2010 at 22:42
oecken
im guessing you dont have a Magnex then... LOL
Posted 21st Oct 2010 at 22:51
adamski_306
Mine does it, I've just decided it's part of owning a 6... Dunno
Posted 22nd Oct 2010 at 02:12
anth
Give up mate, just turn up the stereo.
I have gearstick rattle, center vents rattle, seat belts, passenger door card, parcel shelf.
I gave up
Posted 22nd Oct 2010 at 03:13
monkgti
i know yeah i should prob just live with it, but have to try to fix it at least once before i do LOL
its definitly from around the airbag anyway so mabey its loose or i could wedge somthing in underneath it!!
its just one of those things that i can put up with for a little while and then all of a sudden i just cant listen to it any longer Cry
Posted 22nd Oct 2010 at 04:32
Actually i do LOL
Posted 22nd Oct 2010 at 10:51
oecken
LOL oh! my 3" magnex with devil decat and viper always seems to out do the rattles Devil
Posted 22nd Oct 2010 at 13:21
matt.gti6
+1 on the airbag rattle! It just started one day for no apparent reason.
I am going to try the method I used on my 205 GTI to stop rattly dash syndrome, which involved wedging small slices of bicycle inner tube between the rattly bits! Worked well, and you couldn't really see them... hopefully that will work Smile
Posted 22nd Oct 2010 at 15:09
I have decat, custom centre section and 3" magnex back box, it's insanely loud between 2-3k rpm but bearable outside that range Doh
Motorways are unbearable after 30 mins if i have 70 on the clock. Dry
Posted 22nd Oct 2010 at 21:35
Remove dash, fit cage...
No more creaks, in fact pretty much no more hearing anything once your hearing aid is switched off Razz
Posted 26th Oct 2010 at 14:04
monkgti
definitly one way to solve it anyway Laugh my ass off
Posted 26th Oct 2010 at 18:47
russbez
f*cking group N!!
my old man got in my car the other day and thought my dash was broke or something LOL
My Rallye project thread
Posted 26th Oct 2010 at 20:39
