the rest of the kit looks fine, is the tensioner on the left for a vts or something?
Silver 6
| Author | Subject: cambelt tensioner confusion |
jimmyboycheck
Regular Location: bournemouth Registered: 19 Apr 2009 Posts: 121 Status: Offline |
![]() the rest of the kit looks fine, is the tensioner on the left for a vts or something? ________________________________________ Silver 6 |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
I think that its a 137 tooth kit whereas the tensioner on the right is off a 136 tooth kit.... i'm sure someone will come along and correct me if i'm wrong! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
jimmyboycheck
the one on the left will not fit. the kit was apparently for gti6/vts so is the tensioner for vts. the guide was the same tho________________________________________ Silver 6 |
jimmyboycheck
speaking to europarts this morning, the chap said there is two diffrent cambelt kits. 1 being self adjuster ie on the left in pic or manuall adjust. So hopefully the rest of the kit is ok...........________________________________________ Silver 6 |
it wont be, the belts are a different length by one tooth.________________________________________ Nothing to see here |
Rich E
As above, you need to take the kit back and get the 136 tooth kit.________________________________________ Rich |
jimmyboycheck
well the belt was 136. the tensioner was wrong. i measured up the belt and was 136. now on the car and runing perfect. it looks like tensioner and belt were packed seperatly________________________________________ Silver 6 |
rallyeash
awaiting the bent valve thread...________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
jimmyboycheck
so could someone tell me what car the tensioner is on the left for. So I can sell it on...thanks________________________________________ Silver 6 |
its from the 137t kit by the looks of it.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
xsisid
Newbie Location: lincoln Registered: 22 Jan 2010 Posts: 49 Status: Offline |
the one on the left is for the 1.8 xsi engine. its the only engine that uses that tensioner. i found some info on it on the gates site a while ago. |
jimmyboycheck
rallyeash wrote: awaiting the bent valve thread... seriously if this was the case how long would it take for this to happen. i did measure it up to the belt that came off up and matched tooth to tooth all the way round. or are you taking the p*ss cos you can use 137 or 136 tooth belt.............. ________________________________________ Silver 6 |
miles
Those tensioners are not bad really, the V6 uses them and never get changed until the 2nd belt around 145,000 miles, Saves sticking too much tension on the belt, But more hassle to fit on the 6 engine________________________________________ 306 Rallye Sptint/Race Car, 205 CTI 1.9 8v to name a fewRoad, Track and Race/Rally car preparation to your personal requirements, Full Workshop & Diagnostic Facilities New and Second parts, from Plugs to Turbo's We now also carry out Routine Servicing www.pugracing.com & FB Page, https://www.facebook.com/PugRacing Ebay; http://stores.ebay.co.uk/Pug-Racing-Shop 2012/2013/2014/2019 Class Winners at Gurston Down Speed Hillclimb & Joint overall, Class record too along the way, |
rallyeash
jimmyboycheck wrote: rallyeash wrote: awaiting the bent valve thread... seriously if this was the case how long would it take for this to happen. i did measure it up to the belt that came off up and matched tooth to tooth all the way round. or are you taking the p*ss cos you can use 137 or 136 tooth belt.............. only joking mate. ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
