Author Subject: Oil starvation in the head
darkgti6
What are the symptoms for this? I suspect mine maybe suffering. Is it possible to run the engine without the cam covers on to inspect or will oil p*ss all over the place?
Team Peugeot Sport 308 Gti�
Posted 15th Oct 2010 at 22:02
velar
If oil does not p*ss all over the place, the you definately have a problem.
Even with just the oil filler cap removed and engine at tick over, you should get oil all over the place.
Posted 15th Oct 2010 at 22:56
mabgti
NV motors
starvation isnt too common on the 6 with good pump and sump design. But if you are worried check you oil level and check for leaks first off.. common place is behind the flywheel and rear cam cover..
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 15th Oct 2010 at 23:13
What oil are you using?
Posted 17th Oct 2010 at 05:41
ash306gti6
had a similar problem with my 6... common for the one way valve in the head to get clogged up causing severe oil starvation to top end... i ran mine briefly with the cam covers removed and had no oil hardly coming out the spray bars at all.
try that 1st, check the spray bars if not your looking at head off unfortunatley Sad
Posted 18th Oct 2010 at 18:26
