Author Subject: Update! Cat back on, strange problem! Help :)
rallyestyle
So i have put my Cat back on the SC Rallye ready for its MOT and its now running a bit odd.
Basically sealed it all up nicely so no leaks and all looks good. Took it for a nice drive and it feels really restricted, gets up to about 5k before stuttering. When it idles it also stutters every now and then Sad
Any ideas as to whats going on? It didnt do it last time i changed it over for the MOT Unsure
Cheers guys
Just Drive It
Posted 24th Oct 2010 at 21:41
Are you using the same lambda?
Posted 14th Oct 2010 at 16:24
rallyestyle
Yep Yes If it had just happened over time then i would be certain it was the lambda but in this case it only happened after i put the cat on Dunno
Just Drive It
Posted 14th Oct 2010 at 17:42
lotek
was it mapped with a decat?
Posted 14th Oct 2010 at 19:34
rallyeash
cells colapsed inside the cat?
309 3dr K20 Type R
Posted 14th Oct 2010 at 19:48
rallyestyle
Yes i think, its the generic one. No problems last year though No
Just Drive It
Posted 14th Oct 2010 at 21:01
rallyestyle
:eek Will i be able to see physical signs of this? Looked fine when i chucked it back on Yes
Just Drive It
Posted 14th Oct 2010 at 21:02
rallyestyle
Just noticed a minor few leaks, would they be enough to do it?
Gonna use some sealant to plug them, will do job?
Just Drive It
Posted 14th Oct 2010 at 23:58
willygti
may have damaged the wiring or connection to lambda when you were fiddling around?
Team Ducati 748
2003 Subaru Impreza STi
Posted 15th Oct 2010 at 00:05
rallyestyle
Its always possible i guess but im pretty sure i didnt touch it, its quite out the way really when your squashed under the car LOL Doh
Just Drive It
Posted 15th Oct 2010 at 00:14
You can't use exhaust paste before the cat but after will be fine.
Posted 15th Oct 2010 at 04:05
dragoon
got the same since i've put mine back Sad
it's also got a leak somewhere but i doubt this could be te problem
(even kept cutting out a few times when on idle)
Team Wheelwhore
Team Limited Edition
Astor 306 Francorchamps RIP
Virtual Blue 208 GTi
quote:
I Love this place. So many illiterate deluded fool's acting 'ard . . . and so many literate intelligent people to rip them apart and knock them back down again . . . ahh Cool
Posted 15th Oct 2010 at 04:42
rallyestyle
Cool, its after so all good :thumsbup
Will take it for a spin tomorrow morning before the MOT to see if its improved at all Yes
Hoping it does as i cant afford to be faffing around with it right now Doh
Just Drive It
Posted 15th Oct 2010 at 14:25
rallyestyle
Did it only happen when you put the cat back on or is it an ongoing issue?
If ongoing then it probably means the lambda is on the way out i would say.
Just Drive It
Posted 15th Oct 2010 at 14:28
lotek
tbh i wouldnt worry too much tom, they wont take it to 5k for emissions so wont invoke stuttering, just get it hot and to mot station, then take it off again when your home Thumbs up
Hopefully it will go back to normal Yes
Posted 15th Oct 2010 at 16:50
rallyestyle
I didint realise that buddy, thanks Thumbs up It should be ok then Smile
Just Drive It
Posted 15th Oct 2010 at 17:10
lotek
yeh you should be fine mate Yes
they go up to like 3k rpm i hate watching it its like torture LOL
another reason to ensure its hot, aswell as cat working better
Posted 15th Oct 2010 at 17:14
rallyestyle
Well thanks to the top guys at Pug they scraped it though the emissions test Yes Passed on everything else Smug Its amazing as once again i have done nothing to the car beforehand Smile
STill got issues with the stuttering but im pretty sure its something to do with a boost leak somewhere rather than the exhaust, will investigate this week.
Cheers all Thumbs up
Just Drive It
Posted 17th Oct 2010 at 23:58
dragoon
well I started noticing it since I put the cat back on...
pug did a full diagnostics and didnt see/find anything (only I noticed that the pre-ignition is rather 'unstable')
hopefully you'll get yours sorted Wink
let us know what was/is causing it if you do!
Team Wheelwhore
Posted 18th Oct 2010 at 02:59
mabgti
NV motors
sounds tps related tbh... im in london at the weekend if you want me to stick it on diags...Thumbs up
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 18th Oct 2010 at 19:45
rallyestyle
Cheers Mabs, im a little down south in London (Carshalton) so doubt you will be venturing down there but if so let me know as i might be around Smile I will be taking a look at it on Saturday afternoon hopefully if i get the time Yes
Just Drive It
Posted 22nd Oct 2010 at 14:49
rallyestyle
Well i checked for boost leaks and that was all good, also replaced the cat with the decat so now its back to pre MOT spec, did it work?
No Sad Still sounds like a messasmit and drives like a car with the shits Doh
Im at the point where im going to start having to go through a massive checklist of possible things it could be but before i do its dawned on me that maybe Pug did something to the software while it was in for the orginal MOT (failed on exhaust emissions) as the troubles only started after that Yes Anyone got an idea if Pug might have played with something as part of their MOT procedure?
Cheers all :thumsup
Oh and cheers for the heads up Mabs but i wasnt around this morning sadly Sad
Just Drive It
Posted 24th Oct 2010 at 21:40
