Author Subject: R888
braymond
what PSI are people running R888's at??
Rallye-R
Nurburgring article
Posted 11th Oct 2010 at 21:47
chrisd306
track, 22, road 30 thats what ive been doing anyway
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 11th Oct 2010 at 21:49
liron55
22 ?
aint that low ?
im running R1R on track at 38 PSI. not the same tire but still.
Posted 11th Oct 2010 at 22:49
antn1.b
31 32 felt right for road use to me when i had them depends on a lot of factors though.
Posted 11th Oct 2010 at 22:51
Factory 36 psi, wear rate was terrible but even, at lower pressures I got vague handling and rapidly increased shoulder wear. I am lowered a fair bit and running a little negative camber and more castor up front. Is your suspension standard?
Posted 11th Oct 2010 at 23:51
chrisd306
im running gaz coilovers with a 450lb spring and neg camber top mounts, i find running mine at 22, when i come of the track the pressure is up to 32ish, i used to run at 34 on the track, somebody told me to go lowere, an i found thats good for me, tyre where is pretty even ive found anyway
& Audi Q5 S Line
Posted 12th Oct 2010 at 00:08
jeffers Forum Admin
Look in Faq mate there is a guide from Toyo uk on there that was posted by Farmer... personally i stick to that..... Wink
Team Running Engine again!
Team Negative Camber!
Posted 13th Oct 2010 at 04:41
pdd144c
30-32 psi hot for track use.
FOR SALE
205 Turbo Technics complete and 306 Rallye Race Build breaking.
Posted 14th Oct 2010 at 01:08
r4ly j
Ive had r888 for some time now on road and track.
running them at 30 on road is fine with even wear but track i take them down to 22 front and 26 rear, when up to temperature they reach 32psi.
If you run them anywhere near 30 for track they tend to balloon and wear savagely in the centre, hope this helps
Posted 16th Oct 2010 at 04:00
