Author Subject: Rear shocks help please?. @ what point do i tighten shock bolts?
jimmy9gti
Hi all.
When refitting the rear shocks, or renewing them, does anyone know the correct measurement between the bolt centres before tightening the mounting bolts back up??.
Have heard different opinions and distances.
Afaik, the beam is standard height, and has not been lowered.
Any help much appreciated.
Thanks.
Posted 11th Oct 2010 at 00:09
Rich E Forum Admin
You don't need to worry about that unless you are taking the torsion bars out to change the ride height.
Just fit the dampers and tighten the bolts.
Posted 11th Oct 2010 at 05:01
jord294
Just fit the dampers and tighten the bolts while the weight of the car is on the wheels
Wink
Posted 11th Oct 2010 at 11:47
jimmy9gti
Wink
Cheers for the help Rich and Jord.
Tbh was going to lower car to floor let it settle and do the bolts up.
Makes sense i guess, just didn't want the bushes in the end of the shocks getting twisted out!, as obviously the sleeve is clamped against the side of the mounting bracket when tightened.
Did manage to get hold of a haynes manual, and it quotes 288mm between bolt centres, figures about right i guess.
Posted 11th Oct 2010 at 13:49
