Author Subject: Squeak FML
gilesy
Right, I keep threatening to set fire to it but never do...here goes..
When I was in France my car developed a slight squeak from the brakes. This further developed into a hugely annoying constant squeal. This was diagnosed as a dead caliper OSF so I got a replacement set off someone on here and refurbed them, new innards/seals, new hoses and fitted them all. Squeal still there.
On removing the (original) discs and pads, the OSF pads were about half the thickness of the NSF. So I thought fine, they have been stuck on, and glazed due to the heat. One trip to GSF later and the squeal vanished thanks to new discs/pads.
Until now. I'm now found my rotational squeak again, and is in danger of progressing to the continual squeal sometime soon.
Is there anything that would pressurise just that one braking unit slightly? I've replaced pretty much everything that I can and now its back...
FML
Posted 10th Oct 2010 at 19:22
have you replaced the hoses?
could be a wheel bearing too.
Posted 10th Oct 2010 at 19:25
Hose breaking down inside?
Wheel bearing got a little play?
gilesy
Everything that could be replaced, has. I think bearings are the next port of call. I was thinking it was going to be them as everything else has been done.
Posted 10th Oct 2010 at 19:54
cwspellowe
+1 for bearing tbh
Bye bye Sundance Kid Sad
Posted 10th Oct 2010 at 21:29
Have you still got the rotational squeak?
has it progressed to the continual squeal?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 28th Jun 2013 at 21:37
i8er_4hed
I know wot ur going through, but it is my fault, i fitted the dreaded 406 brembos spent a fortune despite all the warnings, but im too far in now to go back... they squeal like a mother f**K*R...
Posted 28th Jun 2013 at 21:59
i8er_4hed wrote:
I know wot ur going through, but it is my fault, i fitted the dreaded 406 brembos spent a fortune despite all the warnings, but im too far in now to go back... they squeal like a mother f**K*R...[/
Tarrox g88 discs from a xantia I believe with oe pads or better
Or get a kit to move caliper off the hubYes
Posted 28th Jun 2013 at 22:16
FML
Sounds like a balance problem to me have you checked the rears etc ?
Posted 28th Jun 2013 at 22:18
check the Original post date guys, buzz is being a dick.
Posted 28th Jun 2013 at 22:24
i8er_4hed
noted thankyou...
Posted 28th Jun 2013 at 22:48
This. Laugh
Posted 28th Jun 2013 at 23:23
