Author Subject: stud nut or normal bolts?
right i have done a couple tracks day and driven on a couple of my favourite quite country roads and on two occasions my front passenger front wheel has came looseShock once on brands hatch and once on the public road. the wheels at the moment are some tsw multi spoke with spigotAngry not sure if it is the spigots that are causing them to come loose or not.
to be honest the bolts i have at the moment aren't really the best so i was just thinking which to go for???? i would only get the conversion for the front wheels tho
suggestions???
*yes the wheel bolts were tight for you smart assesRazz*
Posted 7th Oct 2010 at 14:36
spiky
neither should come loose so you have an issue that nees resolving,
is there any movement at all on the spigot?
the wheel nuts loose? maybe tge bolt or hub has an issue?
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 7th Oct 2010 at 15:30
checked the spigots the passenger one is abit loose fitting? problem i pose. checked threads and they are all good. only tends to do this with the tws's tho and not the clones.
Posted 7th Oct 2010 at 15:53
Rich E Forum Admin
Do you have the right type of bolts for your wheels?
Posted 7th Oct 2010 at 15:55
rallyestyle
Oddly enough i had one of my old TSW's come loose on me once, it could be some to do with the spigot rings Dunno
Just Drive It
Posted 7th Oct 2010 at 15:58
yeah i have the right bolts checked these. i think it must be the spigot then the passenger front one does come on/off easier than the rest. mite have to swap the rings around and see. but still thinking of studs only thing is i use both the cyclones and tsw's
Posted 7th Oct 2010 at 16:02
ben306
I have the exact same issue with mine. Had a wheel come off at silversone.
I need to order some new bolts, and Im going to clean out all the threads.
Funny enough its the front passenger and its happened a few times now.
My 306 Rallye Project Thread
Lap of Anglesey Coastal
3 sisters circuit
Few laps at Blyton
Posted 7th Oct 2010 at 16:22
hmmmm we must have a similar driving styleLOL think i mite bite the bullet and get some for the front need to speak to someone who has an idea weather or not one stud will do both standard and oe wheels??? i pose i'll just need two sets of nut? flat and tapered ? Huh?
Posted 7th Oct 2010 at 17:53
Are they properly greased up?
Posted 8th Oct 2010 at 01:26
xav
clockwise track? seen it happen to a clio at knockhill. big ass spacers + track = bang!
did ye aye?
Ex Spoox/Trac Prep GTi6 16v turbo - the money pit
Posted 9th Oct 2010 at 01:48
anderoo
I don't see how the spigot rings could cause it but are the bolts long enough?
I had the proper OZ spacer kit with 50mm bolts on my superleggeras and although they didn't come loose it caused a clonking under braking because they were only in a few turns.
Swapped the bolts for studs and nuts and it's been fine since.
Pics of my 6
My 6 on Google Video thanks to coxy306Xsi
Posted 13th Oct 2010 at 14:35
lotek
get some metal spigots greg Yes
those plastic jobbies are not up to the job No
Posted 13th Oct 2010 at 14:58
from??? also karting is 57
Posted 13th Oct 2010 at 15:40
