Author Subject: where to get Coilover top mount Locator 2.5"
these coilovers have proved to be nothing but a pain in the arse,..
when they originally came, the mount that sits between the standard bearing and the top of the spring was a totally wrong fitment
I gave Gaz a ring they sent me a top mount (hat) he called it perfect fit for the bearing case but
to suit a coilover spring ID 2.25 (now I get a horrible rattle with the play of the spring)
I need one to suit a 2.5" spring
does anyone know if Gaz also do the 2.5" version
for the 306
or indeed any other coilover companys that can supply the top mount locator for a 2.5" ID Spring?
Koni Sportsline that originally made the shocks where of no help Dry
I hope this is clear enough LOL
Posted 6th Oct 2010 at 18:28
What size is bearing they have to fit into?
I've a load of 2.5" top spring mounts I made up here for the Fox shocks but I don't know if there's enough material to machine them to fit (they sit around the bearing on the Foxes, rather than in them)
Posted 6th Oct 2010 at 20:18
Ask Curtis at AST - 01684 275000
He might be able to help you.
Posted 6th Oct 2010 at 20:21
it's for one of these
the lip from that sits inside the top of Coilover hat
and the collier from the hat sits inside the spring
Thanks Adam i'll give him a shout Friday
Failing that
Phil I have a spare one of those I could drop round while in your neck of the woods?
How much would you want to machine 1 up if poss?
Posted 6th Oct 2010 at 20:44
Ah, thought you had spherical bearing top mounts - there's not enough material on these to machine them to fit a standard one.
If you can't get any let me know and I'll see if I can get you a couple made.
Posted 6th Oct 2010 at 20:49
