Author Subject: Buying valve guides
Is it possible to get valve guides from anywhere except Pug/Citroen?Smile
Got a head in the engineering shop and he says hes tried all his suppliers and none of them list guides for the Gti6Crazy
Posted 6th Oct 2010 at 17:06
Ask Sandy or Miles Smile
Posted 6th Oct 2010 at 22:49
Ok,thanksSmile
So are aftermarket available?
Presume Miles will sell gen Pug ones?
Posted 7th Oct 2010 at 00:23
I don't know to be honest, Miles has a preferred engine builder that does most of his work I believe.
The valves were TRW and readily available, but not sure on the guides, I know Guy Croft makes guides to spec as and when required, I think Daveyboy may have had a few new guides when Guy did some work on his head.
Posted 7th Oct 2010 at 00:55
Miles does not sell these,PM'ed him Sad
Eng shop reckons he can get race-spec ones from Cosworth,so looks like its either them or PugHuh?
Posted 7th Oct 2010 at 23:11
Try Rich W he may be able to help ?
Posted 7th Oct 2010 at 23:17
Will do,cheersSmile
Posted 7th Oct 2010 at 23:31
Can't he just machine some up? Dunno
Posted 7th Oct 2010 at 23:38
£££££££££££££££££££££££££££££££££Sad ££££££££££££££££££ repeat to fade.....
Posted 8th Oct 2010 at 18:44
chris with a pug
Thats what I am thinking, I thought most engineering places make there own!
Posted 8th Oct 2010 at 19:02
Really needs to be done by a specialist, if the head galls at all when the old guides ar removed it can be a bit of a nightmare getting the new guides in dead centre, which then causes issues with the seat grind as peugeot valve seats are hard as nails.
Posted 8th Oct 2010 at 19:09
Yeah, but if it's the engineering shop that's fitting them anyway...
Posted 8th Oct 2010 at 20:37
Rich does not supply them,he says they usaully 'k-line' guides,not replace them.
What sort of cost would that be would you think though?
I've spoke to Hi-Flow heads,they have them advertised for £8 each,bronze ones Smile
Posted 9th Oct 2010 at 02:44
Probably be about that to have him make them, ask and see!
Tbh, I'd probably send it down to Rich for the K-line liners fitted myself, good quality parts with a good reputation.
Posted 9th Oct 2010 at 03:05
Cheers for info/helpCool
Got them through http://www.enginepartsuk.net
Made by http://www.freccia.com
Wink
Posted 20th Oct 2010 at 16:28
