Author Subject: GTi6 inlet cam timing
JWP EFi
Turbo Legend!
Hi all
After just discovering i can gain extra bhp/torque by retiming my inlet cam (yes, i do have adjustable pullies!) i am now trying to find out how many degrees i can SAFELY advance the timing and where can i get a timing disc from?
i have done a search but could not find any detailed info
cheers
Posted 4th Oct 2010 at 01:31
cwspellowe
Half a cambelt tooth at the MOST, so maybe only a couple of degrees. BHP shouldn't increase but max will be slightly lower down the range, however realistically you're looking at an extra 10lbft if you do it properly Thumbs up
I did it by guesstimation and bricked it when I first turned it over LOL
Bye bye Sundance Kid Sad
Posted 4th Oct 2010 at 01:35
JWP EFi
Turbo Legend!
2 degrees?! i'm glad i didnt do the 5 degrees as was previously suggested to me.
also how does the car drive compared to standard timed 6?
Posted 4th Oct 2010 at 01:49
half a tooth is actually about 4.25 degrees on the cam wheel which I guess is where the 5 degree figure has come from, though as you say its more like 2.125 as they run at half crank speed.
Posted 4th Oct 2010 at 01:54
JWP EFi
Turbo Legend!
good point Welshpug. whats the best way to do this, rotate crank anti clockwise or directlt at the cam and obviously clockwise?
Posted 4th Oct 2010 at 01:56
cwspellowe
I slackened off the cam pulley, turned camshaft clockwise, then tightened up the pulley again.
I have the 3-bolt pulleys though, not as simple on the 1-bolt pulleys
Posted 4th Oct 2010 at 02:07
JWP EFi
Turbo Legend!
i have the 3 bolt pulley too.
did you notice gain straight away or did you have to put miles on the clock so the ecu 'self learned'?
Posted 4th Oct 2010 at 02:14
if you disconnect the battery whilst you do the work it'll self learn in the first short drive.
Posted 4th Oct 2010 at 02:29
anybody want to do mine? i dont trust myself lol
Posted 26th Oct 2010 at 01:44
scoty18
I done mine by turning the crank anti clock wise slightly and tried it a wee bit at a time till I I dared not to go any further. To be honest I think it was a waste of time (for my standard engine)..... Probably get better results from giving the car a good service
  • TEAM DIABLO!!
  • Posted 26th Oct 2010 at 02:05
