Author Subject: f*cked Again :(
vernam616
Follow on from my other thread Sad
Since compression test and refill on saturday, the car has ran great and not got hot.
However today as the missus was coming back on the school run, the temp gauge shot right up again Sad
She told me the car kept cutting out and she had to restart, when i went to the car, big splurgle of water when taking the rad cap off, and noticed the temp gauge was around 100 degrees, however the fan WASNT running ???
Also noticed water in the passenger footwell
Do i have a triple/quad problem here? cutting out, overheating, water in footwell, fan not working?
Any help appreciated
Thanks
Audi S3 Black Edition
Posted 28th Sep 2010 at 21:46
jimmyrallye
bit of topic i know bud but my old mk2 2 golf gti had all of your problems every now and then would p*ss out water and get hot, always carried a 2 litre bottled water just incase, sold it on in the end Sad
Posted 28th Sep 2010 at 21:53
ryangti6
If the water shot out of the cap upon removal it sounds like one of 3 things, dodgy thermostat, air lock or headgasket.
The water in footwell could be the matrix, if this is the case and you are slowly loosing water then that could be the cause of your overheating and also the cause of an air lock. The fan not working isnt going to help matters but you shouldnt need your fan too work to control the temp unless in traffic really.
Likewise with the cutting out, worst case is its cutting out because it is too hot which will have probably done damage, it could be nothing related to the overheating though.
Ryan
rallyestyle
ryangti6 wrote:
If the water shot out of the cap upon removal it sounds like one of 3 things, dodgy thermostat, air lock or headgasket..
Depends if it was hot though, anywhere near 100 degrees and the water will coming flying out no matter what Shock
Just Drive It
Posted 28th Sep 2010 at 21:56
the excess pressure from a failing HG can blow a heater matrix.
Posted 28th Sep 2010 at 23:23
vernam616
compression test shown it to be ok?
180 ish on all cylinders Dunno
Posted 29th Sep 2010 at 00:50
mark-house
Get a sniffer test done on the coolant pressure test wont always show up a head gasket failure
Peugeot 306 GTi 6
BMW 320 td compact M-sport
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 29th Sep 2010 at 00:53
eddy_gti6
i would say heater matrix if there is water in the foot wells also could have a headgasket problem there, is there white shit under the oul cap and rad cap?
Posted 29th Sep 2010 at 01:07
mark-house
wouldn't there only be deposits if the water and oil were mixing? the head gasket may have gone and just be pressurising the coolant causing the matrix to go and leak water causing the over heating?
Peugeot 306 GTi 6
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 29th Sep 2010 at 01:13
eddy_gti6
maybe but last time my geadgasket went i had water oil mix and no problem with my matrix
Posted 29th Sep 2010 at 01:25
vernam616
Ive had compression and sniffer test done both proved ok, however do have white smoke and water in the foot wells, no mix in either oil or water
Posted 29th Sep 2010 at 01:40
mine still went like stink till the day the misfire on startup didn't clear, AdamB can vouch for that Thumbs up
my oil + water didn't mix, like mark rightly said the gasket can go without mixing with the oil.
My matrix didn't let go properly till the night it went.
though I have to say I never did a compression test on it.
Posted 29th Sep 2010 at 01:43
eddy_gti6
if its your matrix, i have a spare 1 here and am just up the road from you Thumbs up nightmare of a job tho
Posted 29th Sep 2010 at 02:00
greenbelt
+1
My car had a dodgy idle for ages. Even before the Track'n'Road RR day back in march where it put out power right where it should have for low boost. It also hesitated in the mornings and this would clear up after a minute or so. My first trackday last month was the final straw as the symptoms got worse and one of the piston rings on the leaking cylinder broke so I got white smoke and crankcase pressurisation Angry
Standard Black 6
Black HBSC6 Smoke
Posted 29th Sep 2010 at 02:10
vernam616
Let me just recap what the actual problems im facing are
White Smoke (not loads)
NO loss of power
NO Misfire
NO oil in water & vice versa
Overheating
Coolant pressurising
Water in passenger footwell
Cutting out
Compression test @ cold shown 175-190 psi on all cylinders
Sniffer/Combustion leak test on coolant proved OK, with no change in colour of the solution
How else would the car produce white smoke, this is a sure sign of it burning coolant, hinting towards HG, water in the footwell is matrix, maybe both are f*cked Sad
Posted 29th Sep 2010 at 03:18
justinaccurate
Sorry to ask a daft question but is the car up to temp with the white smoke? May be condensation?
Posted 29th Sep 2010 at 03:26
jeffers Forum Admin
Sounds like the Matrix is fooked either way, fix that and then see where you stand???Unsure
Team Running Engine again!
Team Negative Camber!
Posted 29th Sep 2010 at 03:38
simonjames
i'd try a comp test when warm and all has expanded
maybe a dodgy water pump not pumping enough i have seen them coming out with a few damaged fins
Matrix has to be leaking for water in foot well
engine must be burning water for white smoke
so i'd say there is more than just the 1 problem
MY EBAY ITEMS
07943066306
Posted 29th Sep 2010 at 03:57
indeed, not a hard job in a wallye, easily done in a day with plenty of tea and biscuits Thumbs up
Posted 29th Sep 2010 at 04:05
eddy_gti6
Laugh my ass off a long day
Posted 29th Sep 2010 at 04:07
the matrix I meant!
Posted 29th Sep 2010 at 04:15
simonjames
Matrix in a few hours Smile
MY EBAY ITEMS
07943066306
Posted 29th Sep 2010 at 04:27
