Author Subject: Changing thermostat with possible waterpump failure.
cd52
Having a cooling issue at the moment. Overheating while running, all fans are kicking in no waterleaks to be seen anywhere and there is no sign of water and oil mixing in the water tank or in the oil so hoping nothing major. Just no cooling of the water so possible thermostat or waterpump impeller failure I think.
The question is, if I replace the thermostat and it turns out to be the pump, can i still bleed the system of air properly?
Posted 18th Sep 2010 at 18:46
ablister
yes, it'll be fine. Engine doesn't need to be running when bleeding the coolant system
306 rallye, Richard Longman engine
rc10gt
Posted 19th Sep 2010 at 16:00
justinaccurate
really? I always thought you had to get it to a certain temp till the fans kick in so you know the water is circulating and all the air is pushed out the system
Posted 20th Sep 2010 at 18:44
cosmic spanner
Moral objector
yeah "the way I was taught" you need to run the engine 'til the thermostat opens.
Democracy is two wolves and a lamb voting on what to have for lunch..
..Liberty is a well-armed lamb contesting the vote.
Project é - my 306 project thread.
Posted 20th Sep 2010 at 19:37
cd52
It's going in for a waterpump and timing belt/tensioner change on Thursday anyway so I'll just let the garage do it all for me. \saves me any hassle.
Posted 20th Sep 2010 at 22:58
ablister
use a modified bottle to fit over the expansion tank then fill with coolant (there's a proper peugeot tool for the joCool. Open up bleed screws (heater matrix pipes, 2 on thermostat housing and radiator) and shut them when all the air has escaped and coolant starts to flow through them. Engine is not running when doing this.
rc10gt
Posted 22nd Sep 2010 at 02:58
mabgti
NV motors
being three bleed points on the gti6 there isnt a need to run it to temp.. but better safe than sorryYes
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 22nd Sep 2010 at 05:50
cd52
Seems to be sorted now. Turned out to be the pump in the end. Impeller failure, pump was still turning from the engine but the blades had worked their way loose from the shaft. Thank God it was nothing more complicated.
Finally have it back on the road after nearly 4 weeks Smile
Posted 24th Sep 2010 at 04:43
silky
Can you go through that again step by step for me please ?
Got to change the rad on my GTI this weekend so will need to bleed the system, thought engine had to be running for this
Posted 24th Sep 2010 at 15:10
cosmic spanner
Moral objector
I have replied in your other thread Wink
Posted 24th Sep 2010 at 16:10
