Author Subject: Track anti roll bar ?
aaronsautos
Anyone know where I can get a good anti roll bar to make my pug stiffer on the track ?
Also it's lowered 50mm and I've adjusted the front camber by 3degrees what do you reckon I should set the track to ?
Posted 17th Sep 2010 at 21:59
3 degrees?
I didn't think you'd get that without the spring touching the turret even with eccentric top mounts on coilovers?
Posted 17th Sep 2010 at 22:31
aaronsautos
Well it is more like 2.7 degrees I had to do a bit of modification but it works fine and doesn't catch anywhereBig grin
Posted 17th Sep 2010 at 23:50
smighall
Smeg-all
I'd set the tow up parallel personally. As per ARB that all depends on spring rates etc.
Meh
Posted 17th Sep 2010 at 23:54
midlife
X2
Go for a hybrid rear arb unless your on 400lb + front springs & 23mm+ torsion bars then you'd need a 30mm rear arb
Cool
Team 330™Cool
Team "no front end or engine"
Posted 17th Sep 2010 at 23:59
aaronsautos
I've got 400lb springs on the front with standard gti torsion bars on the rear.
What are hybrid anti roll bars ?
Posted 18th Sep 2010 at 04:06
Be worth getting hold of some 23mm torsion bars too then.
Posted 18th Sep 2010 at 04:15
and decent dampers Smile
Posted 18th Sep 2010 at 04:14
aaronsautos
Where can I get some 23mm torsion bars from ? And where can I get uprated ARB for front and rear ? Thanks guys
Posted 18th Sep 2010 at 04:28
I wouldnt fit a larger front one, but if you PM "anthony" on here or 205gtidrivers forum he may be able to sort some torsion bars out for you.
Posted 18th Sep 2010 at 04:33
aaronsautos
Cheers for that do you think that will stop the body roll on fast sharp cornering ?
Posted 18th Sep 2010 at 04:44
no, but it will help Smile
remove the springs totally and you wont get body roll, but you wont have any grip either LOL
Posted 18th Sep 2010 at 05:00
If it's only on fast sharp cornering then it's probably the rate of roll you are feeling more - i.e, the dampers need more low speed damping to slow the chassis roll rate.
If it was the springs/arb being too soft then you'd get it on every corner when you loaded up the suspension.
What dampers are you running?
Posted 18th Sep 2010 at 05:01
