Dan
Audi S3 Black Edition
| Author | Subject: Head Gasket/Coolant Problem? |
vernam616
Seasoned Pro Location: Middlesbrough Registered: 01 Mar 2008 Posts: 2,822 Status: Offline |
The missus has broken down in the rallye, she says there was a pop and loads of smoke, aa have recovered her and said the coolant pipe which meets the thermostat housing has popped off and looks like there was a build up of pressure, does anyone know what could cause this or whats wrong?Cheers Dan ________________________________________ Audi S3 Black Edition |
jonnie205
Seasoned Pro Location: Bicester Registered: 10 Apr 2005 Posts: 4,146 Status: Offline |
worst case is head gasket failure, pressurising cooling system |
Rich E
It could be that it wasn't clicked in correctly and just came loose, but yeah, worst case is coolant pressurisation from the combustion cycle.________________________________________ Rich |
rikky
mine blew right in half in 2007 on a b-road without light atall at midnight near enough!just bodged it, refilled and sorted leak and it was ok... ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
vernam616
Little updateGot home and had a look about Now i can't see any mix (oil/water, water/oil etc.) and the car has never ran hot, the pipe is the one which plugs into the thermostat and a clip slides into/over it, the end on the pipe looks a bit chewed and i dont know whether this was caused when it popped off. When clipping it all back together as best i could, that small part of the pipe gets really pressuried, maybe because theres not much water left in the system? or something more sinister Something else to add was when i removed the air filter pipe, there was some drops of coolant inside the throttle body, but this could be cause from the initial pop and water going everywhere and its seeped through the gasket between throttle body and inlet manifold Any help greatly appreciated as im needing the car for the school run on monday Dan ________________________________________ Audi S3 Black Edition |
mechanical_repairs
Try refitting all the pips and as you fill the radiator remove the bleed screw on top of the thermostat housing and once coolant starts to come out hen nip it up.Run the car up then and see what happens mate, very much doubt its the head gasket. Carl ________________________________________ C.G.Cars of Leicester, Peugeot/Citroen/Renault specialist Tel: 01162 624498/07799 405184 WWW.CGCARSLEICESTER.CO.UK36 narborough road south, Leicester LE3 2fn MOT station now open, tests £35 with a free retest. Recovery available with a recovery unit, for those not so local jobs Also offer the loan of a free courtesy car 306 dturbo |
vernam616
mechanical_repairs wrote: Try refitting all the pips and as you fill the radiator remove the bleed screw on top of the thermostat housing and once coolant starts to come out hen nip it up. Run the car up then and see what happens mate, very much doubt its the head gasket. Carl I hope not , its going for a pressure test tommorow, the AA bloke said there could be a blockage somewhere and its popping at the weakest pointSurely id of had some signs previous to this happening if it was HG failure? like the car running hot or maybe a bit of mix? what do you think another possible cause could be Carl? ________________________________________ Audi S3 Black Edition |
vernam616
Right bit of a update, test proved not to be HG , however car did leak a little this morning from around the coolant cap( nissens rad) and upon taking the cap off it sprayed a co siderable amount of water out, so i flushed it through and bled the system and it was only until i blasted the air line around to dry everything that i noticed when blasting the cap area you could see water air bubbles travelling through the pressure release pipe, does this look like the cap isnt sealing correctly?Also the top of the coolant is "frothy" ________________________________________ Audi S3 Black Edition |
might be that the cap isn't being fitted properly, there is two positions on it.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
Might be that the cap has gone weak... I had one do that and whenever I got on track as soon as I came into the pits it dumped water all over the floor, new cap fitted from pug, no more problem! :-)________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
vernam616
jeffers wrote: Might be that the cap has gone weak... I had one do that and whenever I got on track as soon as I came into the pits it dumped water all over the floor, new cap fitted from pug, no more problem! :-) How would the system pressurise though? surely if it had a leak from the cap, it wouldnt allow pressure to build??? ![]() ________________________________________ Audi S3 Black Edition |
Rich E
What HG test did you do?Also, how much water did it throw out, how hot was the coolant and how high was it filled? ________________________________________ Rich |
vernam616
Rich E wrote: What HG test did you do? Also, how much water did it throw out, how hot was the coolant and how high was it filled? Mechanic did a sniff test? some blue solution in 2 glass tubes along with a priming bulb, colour stayed blue coolant was hot and it was filled high from what i can remember ________________________________________ Audi S3 Black Edition |
It will splurge out if you open the cap when its overfilled and hot.When filled to the line and opened carefully when hot you'll get a hiss on the first position, before you turn to the second and take the cap off. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
vernam616
welshpug! wrote: It will splurge out if you open the cap when its overfilled and hot. When filled to the line and opened carefully when hot you'll get a hiss on the first position, before you turn to the second and take the cap off. Does anyone know the correct fill line for a nissens rad, i cant seem to see one ![]() ________________________________________ Audi S3 Black Edition |
ballardpaul
Seasoned Pro Location: Croydon Registered: 22 Jul 2008 Posts: 4,135 Status: Offline |
I couldn't find one either on mine the other day. ________________________________________ Phase 2 Blaze GTi 6 (Standard) SoldPhase 3 Supercharged China GTi 6 (249.8 BHP) Sold Phase 3 Supercharged Diablo GTi 6 (443 BHP)Sold Nissan 350Z (300 BHP) |
vernam616
Yet another update With the car getting hot last night when the missus was using it, i thought i better unplug the brown sensor to allow the fans to run constant, and keep it a little cooler, however after unplugging and turning the ignition the fan did not spin Funny because yesterday when the car got up to temp, the fan kicked in Need some help with this ! ________________________________________ Audi S3 Black Edition |
Rich E
You shouldn't have a brown sensor on a Rallye. The wiring will be there but the sensor was blanked off from the factory.There should be a thermostatic switch in the radiator that controls the fan. ________________________________________ Rich |
vernam616
Rich E wrote: You shouldn't have a brown sensor on a Rallye. The wiring will be there but the sensor was blanked off from the factory. There should be a thermostatic switch in the radiator that controls the fan. Definatly a brown sensor on the thermostat housing If what you say is true, how do i get my fans to run constant? Everything points to HG but sniff test says different, when the missus came home from work and i moved the car onto the drive, car was putting out white smoke, not loads but noticable and constant It'll be getting fixed and sold, had enough now and try cut my losses ________________________________________ Audi S3 Black Edition |
Rich E
Yeah, that's sounding a lot like HG failure.________________________________________ Rich |
paul_13
Senior User Location: Reading Registered: 10 Dec 2008 Posts: 693 Status: Offline |
Compression test it?See what that brings up. Should be around 210psi ________________________________________ 205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit.![]() Private work, not a prob |
vernam616
Rich E wrote: Yeah, that's sounding a lot like HG failure. Surely would show exhaust gases in the coolant though? And going for the compression test on saturday Paul, thanks for the common value ________________________________________ Audi S3 Black Edition |
jimmyrallye
Seasoned Pro Location: portsmouth Registered: 19 Apr 2008 Posts: 3,144 Status: Offline |
hope its not head gasket mate thats the last thing you need ________________________________________ "Police arrested two kids yesterday, one was drinking battery acid, the other was eating fireworks. They charged one and let the other one off." |
paul_13
Pull off the oil breather hose off the rocker cover and see if there's any mayo. The one with the one way black valve will do ![]() Mine was thick of it when it went, but mine went real dramatically thanks to the c*nt who sold me engine with 2 loose headbolts. It still ran! ________________________________________ 205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit.![]() Private work, not a prob |
vernam616
paul_xiii wrote: Pull off the oil breather hose off the rocker cover and see if there's any mayo. The one with the one way black valve will do ![]() Mine was thick of it when it went, but mine went real dramatically thanks to the c*nt who sold me engine with 2 loose headbolts. It still ran! Will do that, cheers I have no mix on the oil cap, dipstick or coolant, and the sniff test said NO gases in coolant And yeh jimmy the last thing i need especially close to xmas , wish i'd of kept the astor Me and the missus on about getting something else, but with me losing so much on the Leon, we cant really afford to lose lots on this one, it already stands me at around £3500 +, but then theres the possible HG to pay for, just might not be viable, plus the fact we cant agree on anything ________________________________________ Audi S3 Black Edition |
