Author Subject: Water leak - O ring ?!
silky
Noticed tonight that I'm losing water, right under the front bumper, below where the lower rad hose joins the rad.
My initial guess, before looking at it, is this join. It could be a break, split or dodgy join. Does anyone know the size of the O ring rubbers in this join ? Though I might just buy a few and use what fits.
It could be something different, going to take the bumper off on Saturday to see if I can spot it. Any tips welcomed
Posted 17th Sep 2010 at 03:01
is it a later 6 with the metal clip on the hose?
1343Z4 END-PIEC GASKET 0.52 GBP
Posted 17th Sep 2010 at 03:31
silky
It's a 97 R plate, not sure if it has the metal clip or not
Posted 17th Sep 2010 at 11:37
eddy_gti6
mine has the metal clip but has started leaking out of where the plastic bit joins the thermostat housing and for some reason my bolts have come lose and wont tighten back up
Posted 17th Sep 2010 at 11:51
silky
Bumper off and check job I think
Eddy, you tried new bolts in that ?
Posted 17th Sep 2010 at 12:16
eddy_gti6
yes, they dont tighten at all, just going to try a new theromstat housing next
Posted 17th Sep 2010 at 12:37
Rich E Forum Admin
Bad news is that those bolts and studs tighten into the head not the thermostat housing. I'd take the housing off and have a look at the condition of the threads in the head.
Posted 17th Sep 2010 at 15:01
eddy_gti6
I have a tap, will tap them and try again see if that works
Posted 17th Sep 2010 at 15:34
silky
Could you try thread lock too ?
Posted 17th Sep 2010 at 15:36
Can be a pita to get that hose back in due to the angle - use a touch of washing up liquid as it helps no end. You won't know what type it is until you look. Mine on an S had the newer style fitted.
Posted 17th Sep 2010 at 15:39
silky
Cheers Adam, I'm hoping that with the bumper off I should be able to have more room to get it on and off, that's if its that causing the problem.
Until the bumper is off I wont know, but the wet patch is right under that join. Though could be the rad in that particular spot
Posted 17th Sep 2010 at 15:41
