displaying posts 1 to 25 of 53
Pages (3): [1] 2 3
Author Subject: Fixed -> Tapper or crank pulley slipped?
mikebee
Hi all,
Have been gradually fixing jobs on my GTi-6 since I picked it up a few weeks ago. It has a 'tap' to the engine which I put down to injector noise initially, but have noticed it more and more having read threads about 'tappers' on here.
Checked the spark plugs. All tight. Checked the compression and I got 192psi, 189psi, 190psi and 191psi so I don't think any valves are bent. Still getting this tapping though.
Vid of noise on YouTube
It had a new cambelt just before I bought it so the only thing I can put it down to is the crank pulley slipped and the tap is valve just touching the piston as the timing is out and they didn't notice.
The car itself pulls pretty strongly and runs smoothly, so it can't be out by much. Either this or a hydraulic tappet, but I've done a couple of long runs and it doesn't clear.
Anyone got any thoughts?
Posted 18th Oct 2010 at 01:01
owww!!! my ears!
its a tapper imo, they don't always lose compression.
a valve will be bent if its touching or ever has touched a piston.
Posted 17th Sep 2010 at 00:43
CUJ
Sad
340 horses
Posted 17th Sep 2010 at 00:49
jeffers Forum Admin
Probs a bent valve, mine ran perfectly after i buggered up doin the timing belt but on stripping had bent at least 2 valves on cylinder 3, replaced all 4 for peace of mind Sad
Team Running Engine again!
Team Negative Camber!
Posted 17th Sep 2010 at 00:59
mikebee
Did yours tap and sound like mine then?
This is not looking good Sad
Can the head be removed from these with the engine in the car?
Posted 17th Sep 2010 at 01:07
felixthecat
Mine sound exactly the same and there were 2 valves bent. You can get the head off without removing the engine but its a bit of a fiddle cause of the exhaust manifold.
306 Gti6 Cherry Red Supercharged Smile
Greets from Germany....
Posted 17th Sep 2010 at 01:18
eddy_gti6
get it fixed mate, mine was a tapper then this happend
snapped a valve and put a hole in the piston, head was totaly f*cked and was the bottom end so basicley new engine job. luckley i had spare parts to build a new engine.
if you loose power n throw white oil smoke out you no whats happend LOL
Posted 17th Sep 2010 at 01:25
CUJ
Mike it can be repaired Thumbs up
340 horses
Posted 17th Sep 2010 at 01:27
rallyeash
Sad head can be removed in situ but be prepared to loose some skin from you knuckles when gettin the zorst manifold off
309 3dr K20 Type R
Posted 17th Sep 2010 at 01:28
mikebee
This is really not good Sad
If it is a tapper I will definitely repair it. Have a very good machine shop about 100 yards from the house which is good!
Apart from the noise then, what's the best way to diagnose bent valves? Obviously the compression test is good, so the valves are seating properly.
Maybe I should just take the car to Carl as he's not that far up the road? Have PM'd him but no reply so I assume he's on holiday or not about?
Posted 17th Sep 2010 at 02:18
jeffers Forum Admin
Remove heatshield then Thirteen mil flex rachet spanner and your knuckles "should" stay intact! Wink
Posted 17th Sep 2010 at 03:49
karoshi
To repair a brand new tapper eg. Slipped timing belt on otherwise brand newie, would just valves and guides be the go?
Seats should be fine ?..............pending inspection.
Bill
Posted 18th Sep 2010 at 03:30
Rich E Forum Admin
The seats may need re-cutting and do occasionally need replacing but they are usually serviceable.
Posted 18th Sep 2010 at 03:36
mikebee
Will have a look this weekend and see if the crank pulley has slipped. I suspect it has and has caused top end damage Sad
Roughly how much am I looking at spending having the head fixed? Assume couple of valves and guides. Should I also have a skim for good measure or is this not required?
Posted 18th Sep 2010 at 15:30
I had four new valves,all valves checked,guides checked,all valves re-seated,pressure test,light skim for £193 at my local head place,Motorcast ComponentsWink
Posted 19th Sep 2010 at 02:29
only skim if required, i.e to clean up the surface or to correct any warping, certainly no more than 0.25mm Thumbs up
Posted 19th Sep 2010 at 02:36
mikebee
Quick update for anyone who's interested.
Had a look at the timing today. Got the camshafts locked in place with 6mm dowels and checked the crank position - see attached. This looks out of time compared to the FAQ which has the key on the pulley in line with the two bolts.
I'm assuming this indicates the crank pulley has slipped??? Either that or it's a tooth out or wrong cambelt fitted. Will take the head off next weekend and have it looked at.
mikebee has attached the following image:
Posted 20th Sep 2010 at 01:11
maddriver9
im having the same problem on the gti6 i just bought.
runs fine for two mins till warm then tapping like in the vid.
so after raeding this i think the head will be coming off for inspection.
178bhp 205gti6
¼ mile in 14.2
Posted 20th Sep 2010 at 12:39
maddriver9
just done a compression test i got
210, 220, 200, 200.
Is it still likely that this could be a bent valve?
178bhp 205gti6
¼ mile in 14.2
Posted 21st Sep 2010 at 00:26
yup!
Posted 21st Sep 2010 at 00:30
mikebee
Another thought I had about mine. What would happen if a 136 tooth belt was fitted to a car with the tensioner from a 137 tooth belt (ie. my phase 3)? Presumably they'd either not be able to tension it or the timing would be out?
I am trying to figure out which belt to get... Seems quite a debate on here!
Posted 21st Sep 2010 at 00:36
you wouldn't get the 136 belt on with a 137 plastic sprung tensioner.
I'd get 136t, metal tensioner FTW.
Posted 21st Sep 2010 at 00:38
mikebee
Okay will do. Just read that you then need a different bolt to fit it in replacement of the 137 one.
Don't know why Peugeot make it so hard.... Would be much easier if they engineered it right in the first place rather than create confusion!
Posted 21st Sep 2010 at 00:40
maddriver9
surely if a valve was bent it wouldnt close proberly.
mikebee does you car tap from start up?
178bhp 205gti6
¼ mile in 14.2
Posted 21st Sep 2010 at 01:03
these have double valve springs, which is one of the reasons the belts need changing more often, and also why a bent valve often still seals very well.
till the day it decides to part company with the stem that is...
Posted 21st Sep 2010 at 01:15
Pages (3): [1] 2 3
