Author Subject: new suspension help
:: blade ::
hi all, reet i think its time i want a new setup on my car, i want to keep it the same height but stiffer, i think im getting a fair bit of body roll as seen in the below pic
(taken at come on he Quarry corner)
i have Bilsteins all around on there atm which are about a yr old, been thinking about getting some coilovers, i know im not goin to get really good ones with my budget but i was thinking of these?
only really want to spend around £250 but no more, or are there any other alternatives that you recommend for around £250 and lower 50mm
cheers
Iain
Black Ph1 XSi-6
161.8BHP (Getting Better!!!!)
Posted 16th Sep 2010 at 23:27
any coilover that side of £600 is going to be a bit poor.
raise the ride height and stick to standard size springs if you can't afford proper suspension.
a hybrid anti roll bar will help.
p.s, that'll be sat on the bumpstops in that pic LOL
Posted 16th Sep 2010 at 23:49
:: blade ::
the beam is fecked in that pic Wink i know im not going to get anything reallllly good for the price i can afford, its not asif its going to be a full time track car, so anything will be better than whats on atm i think Smile
Black Ph1 XSi-6
Posted 16th Sep 2010 at 23:50
not really! standard oem stuff will be better than cheap coilovers.
Posted 17th Sep 2010 at 00:13
:: blade ::
but i dont like standard height :p
doesnt have to be coilies tbh, anything that will give a 50mm drop and be slightly stiffer would be good Smile
Black Ph1 XSi-6
Posted 17th Sep 2010 at 00:16
so you dont like nice handling pugs then? LOL
Posted 17th Sep 2010 at 00:17
:: blade ::
tbh mine now handles better than it did on the standard suspension :p but tbh, i think the suspension ive got on is standard for 6s but with different springs, there the black bilsteins
Black Ph1 XSi-6
Posted 17th Sep 2010 at 00:18
miles
Get some stiffer springs, As said any cheap coilovers will be worse than you have, Plus dampers do not limit roll
Plus go too low and you;ll bugger up the roll center's anyway and make things worse
www.pugracing.com
Posted 17th Sep 2010 at 01:04
:: blade ::
yea dont want to go any lower than what it is, what springs do you recommend? which are 50mm
@miles: abit off topic, do you keep gear linkages in stock? might have a set off you in a few weeks if you do Big grin
Black Ph1 XSi-6
Posted 17th Sep 2010 at 01:06
miles
Falkner springs (May have spelt it wrong) do custom springs
Or fit a 30mm rear ARB, Yes it means machining or replacing 1 arm shaft but for the money it's a very worthwhile mod
Yes I always have the linkages in stk
www.pugracing.com
Posted 17th Sep 2010 at 19:03
bobdylan_55
cant you get uprated springs for use on the bilstein dampers you have?
309 GTi6-T
Posted 17th Sep 2010 at 19:09
lotek
keep the dampers Yes
spend the money on a 30mm ARB and machining the shaft to suit. (im sure teh 205 pins work without machining)
Then get some custom springs or progressive of-the-shelf ones with 40mm drop
the current eibach springs you have are too soft, i had same ones and wasent happy with them at all. No
Posted 17th Sep 2010 at 19:18
ben306
take the springs out then youll get very little body roll
My 306 Rallye Project Thread
Lap of Anglesey Coastal
3 sisters circuit
Few laps at Blyton
Posted 17th Sep 2010 at 20:26
:: blade ::
Well as i need a new beam anyway, how much would it be to get the 30mm ARB and the work needed to fit it? Will the arb just make the rear end stiffer? Cheers
Black Ph1 XSi-6
Posted 18th Sep 2010 at 02:05
:: blade ::
what ARB can i fit without having to mod anything for it to fit?
Black Ph1 XSi-6
Posted 21st Sep 2010 at 00:52
Spoox/Ash hybrid.
or just rebuild your beam and fit new shafts (as most need nowadays) and fit the 30mm.
Posted 21st Sep 2010 at 01:16
:: blade ::
how much would it set me back to rebuild it?
Black Ph1 XSi-6
Posted 21st Sep 2010 at 01:24
depends what's worn, but in parts anything from £35 to £135 + cost of a donor beam for a crossmember tube, if you're lucky and strike upon a set of decent shafts in a donor beam then you'll save £100.
plus labour of course.
Posted 21st Sep 2010 at 01:28
:: blade ::
well id do it myself if its not too hard, picking a standard beam up tomoz for £90 with everything on it and getting the front struts and springs aswell,
Black Ph1 XSi-6
Posted 21st Sep 2010 at 01:31
jord294
willing to help out if i can Wink
Posted 21st Sep 2010 at 03:19
:: blade ::
ahh cool cheers Smile
Black Ph1 XSi-6
Posted 21st Sep 2010 at 03:21
