Just my 2 pence worth if all usual suspects fail
displaying posts 26 to 30 of 30
Pages (2): 1 [2]
| Author | Subject: Help: After Cleaning, Problems :( |
Power steering sensor on the front of the car causes all sorts of funny things to happen to the running of the engine - seen it with my own eyes. Had a couple of cars come in with running probs - changed the sensor all sorted Just my 2 pence worth if all usual suspects fail |
306gti6head
Regular Location: Canterbury Registered: 12 May 2006 Posts: 112 Status: Offline |
Where's the power steering sensor ? (any pics or is it obvious!)& today it seems to idle just over 1k but NOT die ! Hmmmmm ________________________________________ Thank Phat Its Friday Team: Gti6 |
306gti6head
Cleaned the Stepper motor & took the Map sensor off n kind of cleaned it a lil.Car seems fine now, well at least for the moment ![]() ________________________________________ Thank Phat Its Friday Team: Gti6 |
gti-dan
Regular Location: Yorkshire Registered: 03 Jan 2010 Posts: 461 Status: Offline |
bigbadbowen wrote: Nope car will run fine without that pipe Pretty sure that *could* be causing the problem. Yes - the car will run fine if nothing is connected to the cam over outlet, but at the other end of that pipe it is connected to the inlet behind the throttle plate so the engine can suck unmetered air through the pipe causing it to rev. Could explain why the problem only kicks in after a while...could be that the pipe heats up a bit and the split allows air / more air down into the engine. |
306gti6head wrote: Where's the power steering sensor ? (any pics or is it obvious!) & today it seems to idle just over 1k but NOT die ! Hmmmmm Follow the power steering pipes bud its a blue sensor if I remember correctly ? |
Pages (2): 1 [2]
