Author Subject: is there a Caliper/hub tool to?
open up the back where the leg of the suspention strut fits into the caliper
I'm tempted to just use an old chisels etc but I'd rather the proper tool for the job, any one know what it's called?
Posted 13th Sep 2010 at 19:26
Rich E Forum Admin
The strut goes into the hub not the calliper.
You can release the clamp with...
Posted 13th Sep 2010 at 16:02
I was thinking because the whole lot would come off in one go! Razz
so one of these would do the job?
Posted 13th Sep 2010 at 19:25
In that case just take an angle grinder to the car around the A-pillars, everything really will come off in one go Wink
I believe the tool of choice is an 8mm square sump plug bit, jam it in the gap and rotate it with a breaker bar. No need for spending money on expensive tools.
Posted 13th Sep 2010 at 20:32
that sounds like a botch job to me LOL
Posted 13th Sep 2010 at 23:25
strut goes into the hub carrier, and as above you can use an 8mm square sump plug key, or an allen key.
most of the time though simply removing the bolt will suffice.
its not a bodge.
Posted 13th Sep 2010 at 23:27
jim01uk
I sell snake oil. would you like some?
Posted 14th Sep 2010 at 01:07
Captain_Cock_Rot I'd like to see the evidence 1st Wink
Posted 14th Sep 2010 at 18:56
bennn
Whack an allen key in the back of the hub and turn it to open up the hub. Failing that smack with a hammer and it will come free
Cherry Red 306 HDI
Posted 14th Sep 2010 at 19:02
silky
I use an old hub pinch bolt, just tap it in with a hammer to open it up to slide the bottom of the strut in, then just tap it with the hammer again to knock it out
Posted 27th Sep 2010 at 16:32
