Author Subject: cant make my mind up any advice
gtomi-6
i lowered my 6 on a set of eibach springs a few months back, at first i loved it and thought it made such a differnce, recently my girlfriend has brought a 6 and it handles very nicely. lowered 60mm on gmax springs and bilstein b6's, i love its stance and am impressed with the handling. its got to the time where i desperatly need to spend some money on mine, as i will be going all out on this the whole suspension will be up graded. im not to keen on the gmax springs any other options? i was told about chassis dynamics or faulkner??? they will be matched to billy b8's, new top mounts and bearings,roller bearing bushes, uprated lower drop links, and top and bottom strut braces. i also have a fully rebuilt rear beam with hybrid arb and solid rear mounts. does this all sound ok advice needed. thanks tom
ph3 gti-6 china blue- mint condition
ph2 gti-6 nile blue K.I.A dec 2010
Posted 9th Sep 2010 at 23:08
dragoon
coilovers is the way to go Wink
kw or something alike
Team Wheelwhore
Team Limited Edition
Astor 306 Francorchamps RIP
Virtual Blue 208 GTi
quote:
I Love this place. So many illiterate deluded fool's acting 'ard . . . and so many literate intelligent people to rip them apart and knock them back down again . . . ahh Cool
Posted 10th Sep 2010 at 02:10
sounds alrite to me. i have solids hybrid arb upper brace zx rear shocks with b4s on front standard bushes on front standard droplinks 30 drop and handles like a dream. set up my friend
Posted 10th Sep 2010 at 02:34
gtomi-6
I want the 60mm drop for the looks. But not if its goin to ruin the handeling
Posted 10th Sep 2010 at 03:58
lotek
if you want 60mm drop and wanna keep handling you need a decent set of coilovers.
Posted 10th Sep 2010 at 04:09
gtomi-6
No way I can get that from b8's and a stiff set of springs
Posted 10th Sep 2010 at 04:13
Rich E Forum Admin
B8's are very good dampers for the 306. They are actually just a short rod version of the B6 damper (the B6 and B8 rear damper are the same part.)
I've run them on Eibach springs with 21mm torsion bars and found this to be an excellent setup. I've not gone any lower than this though, as I liked this setup very much.
One of the most important things for the feel and balance of the car is that the change in spring rate is matched at the rear which is something most people don't bother with.
Posted 10th Sep 2010 at 04:24
gtomi-6
Thanks rich great advice
Posted 10th Sep 2010 at 12:18
gtomi-6
It deffinatly has to be lower than it is now. 30 mm just isn't enough for me. I want it to handle like its on rails. Since being in my mrs I hate mine. Its not rubbish but its nothing in comparison. I get way to much body roll
Posted 10th Sep 2010 at 12:27
You are confusing handling with grip. They are different.
I agree with you there Rich, but a huge amount depends on the quality and control of the rear dampers as well. Made by far the most obvious handling difference on mine when I was buggering about with it.
Posted 10th Sep 2010 at 14:16
gtomi-6
So when I get my b8 rears they are bassically the same as b6 ones? It will be a full rebuild anything that needs doing will get done as it needs the money spent on it. Following that the brakes and then should be ready for a new set of shoes, fingers crossed when all done it should handle very well. Unless I'm missing something
Posted 10th Sep 2010 at 15:12
