Author Subject: 306 GTI 6 JOLTING DURING ACCELERATING
johnyv5
when I drive my car and it gets chance to warm up generally in traffic on the way to work, it will start jolting when accelerating or even driving at a steady pace (kangaroo style)and becomes very irritating, it does this mainly in warmer weather and will not do it as much when it is cold or raining, I have had this problem now over a year and have spent about £300 on people fault finding to no avail.... any comments???
Posted 8th Sep 2010 at 04:27
james_gti6
possibly one of the engine mounts. drivers side
if i dont see you in the mattress il see you in the spring
Posted 8th Sep 2010 at 04:30
jeffers Forum Admin
Hmmmm Lambda, map or TPS?? or CTS is my guess,follow the FAQ for sensor testing mate should point you in the right direction!Wink
Team Running Engine again!
Team Negative Camber!
Posted 8th Sep 2010 at 05:00
paul09675
It sounds like one of your coils is on the way out. I had the same problem on my 97 gti6. Had it into Peugeot a few times and on the diagnostics but it did not show up anything. Buy a new coil and swap it in turn with all 4 coils until you find the one at fault
Paul D
Posted 23rd Sep 2010 at 01:33
vernam616
Could be TPS mate depending how bad the jolting it, mine did the same whenever backing off the throttle, spent money getting mounts done and it was still doing it, changed TPS and all was ok
Try disconnecting the TPS and taking it for a drive, if it drives smooth, you'll know thats the culprit (you will notice power loss with it disconnected as it uses default values from the ECU)
Hope this helps
PS. TPS is located underneath the throttle body, youll have to remove the air pipe leading to the inlet manifold to get your hands underneath
Audi S3 Black Edition
Posted 24th Sep 2010 at 22:10
To make it easier for us to diagnose what it might be can you tell us what you've changed please?
CheersThumbs up
Posted 25th Sep 2010 at 00:55
mabgti
NV motors
bets on TPSYes
if your stuck give me a shout i'm in london most weekends. So could pop it on the diagnostics for tracing not just fault codesSmile
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 25th Sep 2010 at 02:09
